A/C fan quetion
Old Aug 13, 2012 | 01:37 PM
gertie240's Avatar
gertie240
Default A/C fan quetion
Finally going to get the a/c fixed in the ram. It came from the factory with it but there is not a electric fan by the condensor. Should I put an aftermarket puller in there or would that block to much from the clutch type radiator fan and cause overheating?
Old Aug 13, 2012 | 04:16 PM
Shouldn't need an additional fan......
Old Aug 13, 2012 | 04:20 PM
peshewa's Avatar
peshewa
Better to remove the clutch style & go all electric otherwise add nothing.
Old Aug 13, 2012 | 06:23 PM
gertie240's Avatar
gertie240
thanks for the feedback, I am still a little scared of the e-fans. Do you guys keep your old fan with you just in case?
Old Aug 13, 2012 | 11:33 PM
jondakotaguy's Avatar
jondakotaguy
In this Texas Heat I would :X.. LOL... Unless you get a big enough fan and good shroud..
And not being mean but what is quetion?
Old Aug 14, 2012 | 03:02 AM
peshewa's Avatar
peshewa
I used leftover fans from a bonneville i used to own with an upper hose splice in adapter to accomodate the screw in type fan switch. I also installed an over ride switch on the dashboard but rarely ever use it. I got rid of the shroud but did cut thin sections out of it then turned them around & screwed them in to make a good spot to relocate both resiviors. There is now a Ton of room to do stuff under the hood. search my handle to see the wiring diagram i used. My truck runs way Cooler without the shroud.
Old Aug 14, 2012 | 08:39 AM
gertie240's Avatar
gertie240
Sorry if my ramblings were vague, would a aux. e fan on my condensor block too much air flow to my radiator?
Just looking for insight
Old Aug 14, 2012 | 03:29 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Nevermind. sorry
