Front axle drop
Old Aug 17, 2012 | 11:24 PM
3dubs's Avatar
3dubs
Default Front axle drop
I checked in the FAQs, DIYs & How To's and found lfts but not how to get the springs out. I got a 2" leveling kit. It say to jack the truck up put it on stands and the drop the fornt axle. I have the shocks out and the upper shock tower is off both sides. But when I lower the jack it does not go law enough for the springs to come out. I see all kinds if wires and tubes. But what can be holding the axle up? I will be back under the truck as the sun comes up. Could the sway bar be holding it up? I lightly it with a small sledge to see if it would move at all but nothing gave. I figure I better disconect all the wires and tubes. But when I hit it with the small sledge I might as well as hit an anvil so it can't be the wires holding it
Old Aug 17, 2012 | 11:57 PM
dlyter09's Avatar
dlyter09
Disconnect the sway bar. Should give you enough space to get everything out
Old Aug 18, 2012 | 12:26 AM
3dubs's Avatar
3dubs
That is what I was thinking but ran out of light. Thanks, working in this heat with no shade really makes it hard to think clearly.
Old Aug 18, 2012 | 12:47 AM
Wombat Ranger's Avatar
Wombat Ranger
Install Fuzzy Dice.
Old Aug 18, 2012 | 12:52 AM
Matt Nickerson's Avatar
Matt Nickerson
If all else fails...
Originally Posted by 2x1972
Install Fuzzy Dice.
Old Aug 18, 2012 | 06:55 AM
dhvaughan's Avatar
dhvaughan
or use coil spring compressors to shorten them up.
Old Aug 18, 2012 | 09:47 AM
3dubs's Avatar
3dubs
After some rest I feel stupid. I am just used to leaf springs. I am way over thinking this.
So fuzzy dice, hold my tounge right, and use a bigger hammer I have it now.
Old Aug 18, 2012 | 10:43 AM
merc225hp's Avatar
merc225hp
To make it really ez
Remove the sway bar
unbolt the drag link from the pitman arm
unbolt the track bar
unbolt the drive-shaft
Doing this will let the diff drop fully and ezly to the point you need, yes it's a little extra work but it helps a lot.
Edit: Watch those front brake lines they only go so far.
Old Aug 18, 2012 | 11:42 AM
QuadCabLuv's Avatar
QuadCabLuv
Or just rent some spring compressors and not have to do any of that.
Old Aug 18, 2012 | 01:32 PM
Wombat Ranger
All I disconnected (yes, on my 2500, I doubt it makes much difference) was the sway bar and the shocks. Did it with wheels still attached.
