magnum valve train and heads on la block?
Old Aug 20, 2012 | 11:53 AM
  #21
Gary-L's Avatar
Gary-L
Veteran: Navy
How to Rebuild Mopar Magnum V8 How to Rebuild Mopar Magnum V8
A great book for every Magnum owner. IIRC, the heads are not interchangeable, and this entire project sounds like a three-ring circle jerk.
Old Aug 20, 2012 | 12:22 PM
  #22
my99ram's Avatar
my99ram
A great book for every Magnum owner. IIRC, the heads are not interchangeable, and this entire project sounds like a three-ring circle jerk.[/quote]
so you need to tell me all the old la motor guys out there that have done the magnum head swap didnt really do it?????and by all means keep ur rude comments to ur self
Old Aug 20, 2012 | 12:38 PM
  #23
Gary-L's Avatar
Gary-L
Veteran: Navy
Found what I was looking for:
Differences Between Magnum Heads and LA Heads
  • Valve Covers: Magnum valve covers are squared at the ends. LA covers are rounded at the ends.
  • Valve Cover Bolt Pattern: Magnums have 10 bolt valve covers for better sealing. LA covers have 5 bolts
  • Combustion Chamber: Magnums are a closed chamber design. Most LA heads are open chambered except for 302 and similar castings and some early 273 castings
  • Intake Valve Size: Stock Magnums have 1.920" intake valves. The larger LA intake valves range from 1.88" to 2.02". (Note: Mopar Performance does offer Magnum R/T heads with 2.02" intake valves.)
  • Exhaust Valve Size: Magnums have 1.625" exhaust valves. The largest LA exhaust valves are usually 1.60"
  • Valve Stem Size: Magnums have 8mm sized valve stems, which are lighter than the LA 3/8" sized valve stems.
  • Heat Crossover: Magnums have no intake manifold heat crossover like LA heads.
  • Rocker Arm Mounting: Magnums have stud mounted rocker arms. LA rocker arms are shaft mounted
  • Rocker Arm Oiling: Magnum rocker arms are oiled through the pushrods. LA rockers are oiled through the shafts from block passages
  • Rocker Arm Ratio: Magnums arms are 1.6:1 ratio. LA rocker arms are 1.5:1 ratio.
  • Pushrods: Magnums have hollow pushrods to feed oil to the rocker arms. LA heads work with solid pushrods. (Note: There were some LA roller cam engines that were built with hollow oil-through pushrods.)
  • Intake Mounting Bolt Holes: Magnums have vertical intake mounting bolts. LA heads have angled intake mounting bolts.
  • Head Bolts: Magnums require different head bolts than LA heads.
  • Accessory Bolt Holes: Magnums have 5 accessory bolt holes on each end. LAs have 3 accessory bolt holes on each end.
  • Intake Airflow: Magnum intake airflow is about 190 CFM. LA intake airflow is about 160 CFM.
  • Exhaust Ports: Magnum exhaust ports do not have the "point" on the floor like LA exhaust ports.
"Ur"? What does an ancient city of ancient Mesopotamia have to do with
anything? You appear quite unliterate.
As an aside -- don't post in a public forum if you can't handle the comments. Believe it or not, in real life not everyone deserves a trophy for participating.
Old Aug 20, 2012 | 01:34 PM
  #24
my99ram's Avatar
my99ram
will the magnum timing cover fit on a la block?
Old Aug 20, 2012 | 03:50 PM
  #25
crazzywolfie's Avatar
crazzywolfie
i think you are mixing info up. most people with older vehicles do not swap magnums heads onto there old engines. they swap the whole engine. the magnum engines will bolt right into a older dodge vehicle but the older dodge engines will not bolt into the newer dodge trucks.
Old Aug 20, 2012 | 03:55 PM
  #26
zman17's Avatar
zman17
Retired Moderator - RIP
This whole project/concept/idea, has fail written all over it. Of course that was if it was ever really going to happen to begin with.
Old Aug 20, 2012 | 04:07 PM
  #27
Gary-L's Avatar
Gary-L
Veteran: Navy
Now you're being mean as well. Someone's going to be very upset because momma said he was special.
Old Aug 20, 2012 | 04:26 PM
  #28
zman17's Avatar
zman17
I swear it's not my fault. It's the way I raised with all the abuse from that paddle hitting my ***.
Old Aug 20, 2012 | 07:05 PM
  #29
my99ram's Avatar
my99ram
why dont u guys go **** on your own threads. and grow up while your at it
Old Aug 20, 2012 | 07:13 PM
  #30
QuadCabLuv's Avatar
QuadCabLuv
This project fails because the magnum motors are superior in every way to the la. Why bother with it?
