magnum valve train and heads on la block?
Old Aug 20, 2012 | 11:23 PM
  #41
Trapper723's Avatar
Trapper723
Oh myyy hahahaha!! Yes the mag timing cover will work. If you use the mag timing cover you have to use a cam for a mag setup. The shout is what's longer for the mech fuel pump on LAs. The mags have a shorter shout because it use electric fuel pump. But you can use a mag cam with a LA cover and mech pump if you use the extension Hughes sells.
Mag heads are on 1000s of LA blocks btw lol.
The only issue I see is the lifter retaining plate. But drilling an tapping would fix that. It's not a retarded project if it's all you got man. It's simple really.
Don't be afraid just do it an drive that thang!
Old Aug 20, 2012 | 11:25 PM
  #42
Trapper723's Avatar
Trapper723
Snout is longer btw not shout
Old Aug 21, 2012 | 02:39 AM
  #43
Trapper723's Avatar
Trapper723
Originally Posted by my99ram
why amc push rods?i just had my magnum 318 apart and it had the hollow push rods in it.
not amc pushrods hahaha either magnum roller lifters or amc flat tappet lifters with make it send oil through hollow pushrods
Old Aug 21, 2012 | 04:49 AM
  #44
Gary-L's Avatar
Gary-L
Veteran: Navy
hahahahahahaha
ur post mad me rofl!
