Ultrapower O2 sensor
Old Aug 19, 2012 | 05:07 PM
ZeroZero3's Avatar
ZeroZero3
Default Ultrapower O2 sensor
Are these any good? in my search for part numbers I emailed rockauto and they suggested the Ultrapower for the upstream sensor because it's one of there more popular items.
Any feedbacks?
Old Aug 19, 2012 | 05:53 PM
ReadRam's Avatar
ReadRam
Denso and NTK are usual recommended on here and are considered OE replacements.
Old Aug 19, 2012 | 05:58 PM
kejobe's Avatar
kejobe
Yup. X2.
Old Aug 19, 2012 | 06:42 PM
dhvaughan's Avatar
dhvaughan
i'd stick with the basics and look for best pricing on those brands. consider a universal fit if it saves you any money. you just splice it into your old pigtail with butt connectors.
Old Aug 19, 2012 | 08:12 PM
ZeroZero3's Avatar
ZeroZero3
I asked them about a upstream from Denso and they don't have them. I will ask for NTK next time.
Old Aug 20, 2012 | 09:18 AM
drewactual's Avatar
drewactual
ngksparkplugs.com... drill down and find 'em.. as cheap there as any other place, and you'll get the right one..
I respect dhv's opinion on most everything he's ever contributed, but I strongly disagree with using a universal, and even moreso pigtailing them in.. o2's operate by minutely altering voltages, and pigtailing even a OE one is a very bad idea..
the issue with Bosch or other brand o2's is the latency of the reading.. it is either too fast or too slow, I can't recall which- but both are bad.. problem: it will 'operate' inside of the fault parameter (won't set a code), but won't perform as you need it to do the job it's intended..
Old Aug 20, 2012 | 02:21 PM
ZeroZero3's Avatar
ZeroZero3
I am with you on this one, especially after reading a lot of your treads on these sensors with much interest.
Now I have these part numbers from NGK for the upstream sensor, Left 23506 and Right 23151.
Wich one is the good one for a 2 sensors, 2-in-1 catalytic converter setup??
Old Aug 20, 2012 | 02:23 PM
You want the Right version. The left one only shows up on Cali emissions trucks.
Old Aug 20, 2012 | 02:49 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The Denso or the NTK at Rock Auto are less than $35, for the "right" version. Use the discount code and save a little more. Do not get a cheap universal and use butt connectors no matter where you live, "butt" especially not since you live in the Northeast.
Old Aug 20, 2012 | 11:01 PM
dhvaughan's Avatar
dhvaughan
dang. my ears are burning.
