8 or 12 pin od solenoid
Old Aug 22, 2012 | 04:22 PM
cutthroatxxx's Avatar
cutthroatxxx
Old Aug 22, 2012 | 04:23 PM
That last one should be it.
You want the solenoid set.... O/D and TCC. will come with the other end of the electrical connector you see there.
I'm off to work.... Have fun!
Old Aug 22, 2012 | 06:30 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by cutthroatxxx
You do realize that you have to remove the pan and quite possibly the valve body right?
Old Aug 22, 2012 | 10:12 PM
cutthroatxxx
Yes...Incase that dosnt fix it Im insure if I should replace tc or just do a whole new tranny.Called around today found one shop 1400.00 rebuilt with all new electronics&tc &20k warranty or a fella down the road rebuilds em for 700 but Id have to pull&install.Or 900 for a reman.
I thought before it was a miss that caused the shake@46 but did comp test,was fine,new plugs,wires,cap&rotor...gutted cat nada.I didnt route wires per tsb but going to this weeknd.Im wondering if the tsp could cause it?No funny rpms&shifts fine.Had all of the suspension looked@by 4 shops.But still have that code 37 so figured Id try.It sucks with obd1&throwing parts guessing sucks too
Old Aug 23, 2012 | 05:51 PM
zman17's Avatar
zman17
Look at this and read note #1 regarding the 37 code. A simple pcm reset may fix it or you actually have a temp sender. http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
Old Aug 23, 2012 | 11:58 PM
cutthroatxxx
Thanks inless Im wrong all I have to do to reset the pcm is disconnect the battery right?If so I dad that..so I looked for the trans temp sensor &didnt have a placet for it a bit back so I blew the code off.But Give been getting that shaking right @ 45 since I changed the plenum so...I changed or checked everything I could think of that could cause a miss...except for the propri routing of plug wires which I will do this weekend but I do have the good wires.
Well thanks to the search fatture Give sound tons of diffrent threads about the trucks shaking@45&seems like there can be ton of cause.Im gonna pick up a new tps &wondering If I could swap out iac &map sensor while Im at it.I don wanna just throw parts at it but Im out in the boonies&takes me like an hour trip to go get a part.Only vehicle I had before that had a bad tps was just not letting me do more than 40&was rough.So kinda diffrent.
Also as I said it happend right after I did the plenum fix&when I did it I did the egr delete&I drove it&shaked like an earthquake,what happend was I forgot to but the plate on the intake&header so I did&it fixed it&Thats when the shaking@45 began.All in the same day so Im wondering could that of made the iac or tps or map think something was off still?
I didnt think about it till today.Always sorry so long&I would apprezzate any help. Thanks inless Im wrong all I have to do to reset the pcm is disconnect the battery right?If so I dad that..so I looked for the trans temp sensor &didnt have a placet for it a bit back so I blew the code off.But Give been getting that shaking right @ 45 since I changed the plenum so...I changed or checked everything I could think of that could cause a miss...except for the propri routing of plug wires which I will do this weekend but I do have the good wires.
Old Aug 24, 2012 | 08:41 AM
I still think you have a miss..... Re-route the plug wires, make sure the order is correct... re-check codes before you reset the PCM again.. see if there are any misfire codes....
Old Aug 24, 2012 | 03:01 PM
cutthroatxxx
Will do...I have msg wires,new cap rotore,col,did a compressione test so If the re router dosnt fix&the cats gutted no idea what else could be causing a misfire...its obd1 so nota sue If Id even get a misfire code
Old Aug 25, 2012 | 09:14 AM
Good point, no, you won't get misfire codes.... an advent of OBDII... Unfortunately.
Old Aug 25, 2012 | 02:27 PM
cutthroatxxx
Sorry...I hate t9 I meant msd wires cap wire plugs etc...I did However swap in a new col las nite&the truck dose seem to be running a little smooter.Im pretty sure the old one was stock!Its hard to tell If it cured my problem.Reason being I live out in the country where all of the road are lettere highways&there pretty rough&with the big tires Its already a rough ride&the shake @45 int reale hard so Its easy to overlook.Anyways that being said...it looks like the po didnt have to replace any of the sensors so Im gonna go ahead &swap out the tps&but the tcc/od deal in seeings I got it.
