Cylinder head Job, or Mopar performance heads
Old Aug 30, 2012 | 03:17 PM
DodgeTh1s1's Avatar
DodgeTh1s1
thanks guys great advice and links really helped out alot found some odessa heads on ebay for $565 for both with everything, now we got that out of the way should i get some new head bolt and push rods
Old Aug 30, 2012 | 03:20 PM
QuadCabLuv's Avatar
QuadCabLuv
For a little more money you can buy their monster heads with 2.02 valves
Old Aug 30, 2012 | 04:18 PM
DodgeTh1s1's Avatar
DodgeTh1s1
would switching to a roller rocker are set up cause me to have to go with a different lifter set up too
Old Aug 30, 2012 | 04:27 PM
The harland sharp non-adjustable rockers (in 1.7 ratio...) are a direct bolt on replacement for the stock stamped steel fellers.
Old Aug 30, 2012 | 09:31 PM
DodgeTh1s1's Avatar
DodgeTh1s1
anything else i can do with i got it all pulled apart the free up some extra horses
Old Aug 30, 2012 | 10:03 PM
gdstock's Avatar
gdstock
Did you change timeing set? If not, do that and use double roller chain.
Old Aug 30, 2012 | 10:06 PM
drewactual's Avatar
drewactual
Port match everything along the way while putting it back together.. every 10cfm through the engine adds a pony.. you can likely open up 160cfm through the engine for some noticeable gain in the neighborhood of 20hp..
Old Aug 30, 2012 | 10:14 PM
gdstock's Avatar
gdstock
+1 on port matching. I would polish ports as well. I have always done both on any engine I have rebuilt.
Old Aug 31, 2012 | 12:27 PM
DodgeTh1s1's Avatar
DodgeTh1s1
but what did you do on the intake side since its not direct injected
Old Aug 31, 2012 | 12:35 PM
DodgeTh1s1's Avatar
DodgeTh1s1
anyone know of a good website to look this stuff up on summitracing.com doesnt really have alot of stuff for mopars newer than 91'
