Wobbling Crankshaft Pully
Old 08-30-2012 | 03:52 PM
QuadCabLuv's Avatar
QuadCabLuv
Heyyou is correct again. And i cant stress how important it is for a motor to be correctly balanced.
redneck_ram's Avatar
redneck_ram
318's have a 2 piece balancer. pulley can be unbolted. check the bolts, and make sure they arent loose. i have a stock pulley if you need one. pm me if thats what you need. i went with an under drive pulley, so i dont need the stock one anymore.
Old 08-30-2012 | 07:01 PM
DodgeRam10's Avatar
DodgeRam10
i noticed mine wobbling after all my repairs also,didnt think too much about it now im paranoid ive been driving it for about 4 months like that
Old 08-30-2012 | 08:13 PM
95RAM360's Avatar
95RAM360
When my harmonic damper split in two my motor was running very very rough...but was still able to drive it a half hour back home...changed it and runs great didnt damage anything...so if your not running rough you should be ok but id inspect it and see if its the rubber about to be spit out.
Old 08-30-2012 | 08:42 PM
DodgeRam10's Avatar
DodgeRam10
yea i just went and looked again, it definitly doesnt look still like a pulley or anything but its not wobbling krazy or anything. Truck runs great except my ac but im working on that
Old 08-31-2012 | 04:50 PM
OliverWalley's Avatar
OliverWalley
Redneck_Ram, I tried to PM you but your box is full. I'd like to discuss your stock pulley. Thanks
Old 07-11-2015 | 08:41 PM
tony78's Avatar
tony78
Default 96 dodge ram 1500 4x4
At idle my crank shaft pulley ticks and has a slight wobble, doesn't do at higher rpms.. can I drive it like this, or what should I do?
Old 07-11-2015 | 11:43 PM
ReadRam's Avatar
ReadRam
You should start your own thread first to get more replies. Can you get movement of the pulley by hand? Is the rubber slipping out or hard and deteriorated? The dampener on the 5.9 has a cut out that gives the illusion of wobbling.
Old 07-12-2015 | 02:45 PM
tony78's Avatar
tony78
First time on here didnt know how, i can't move it by hand at all... I have a ticking noise in my engine and was looking around to see what it was, crawled under the truck and noticed it coming from that pulley.
Old 07-12-2015 | 05:48 PM
ReadRam's Avatar
ReadRam
No problem. Just click on New Thread on the thread subject page.
Quick Reply: Wobbling Crankshaft Pully
