i have o/d then i lose it after a bit
Old 09-02-2012, 07:17 PM
bergoff's Avatar
bergoff
bergoff is offline
Default i have o/d then i lose it after a bit
Well I was having shifting issues where it would hang in 2nd till I shifted it by hand. I replaced the 2 sensors that was suggested by everyone and seen on youtube. Also changed the filter and fluid. The truck shifted so smooth and was great for the first 30 miles. Then I lost o/d while sitting at a stop light. You can press the button and nothing happens. It used to do this before I replaced the sensors also. What do you guys think. The truck only has 62k on it and is a 98.
Old 09-02-2012, 08:13 PM
dlyter09's Avatar
dlyter09
dlyter09 is offline
How do you lose O/D sitting at a redlight??? The light turns off?? Need a little more info here..
Old 09-02-2012, 08:58 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,402 Likes on 3,142 Posts
Actually, I think the light would turn on......
If that's the case, get rid of the check valve in the trans cooler up near the radiator. The rubber hose that goes to the lower fitting has the valve in it, right where it transitions from steel (coming from the trans) to rubber. Drill it out. Replace it with a piece of hose, and some clamps. Anything. Just get rid of it.
Old 09-02-2012, 09:49 PM
bergoff's Avatar
bergoff
bergoff is offline
Its weird the light will just turn on and it has no o/d. Also while driving I've had it down shift ti drive for about 30 miles and then just shift back to o/d. That was on our way back from vacation pulling our pontoon. I will remove that check valve on my next day off. Heading to the river tomorrow with our new boat so I wont be using o/d anyways.
Old 09-02-2012, 10:14 PM
HeyYou is offline
Remove the check valve BEFORE you tow anything again. What I suspect is happening is the trans is getting hot, and disabling overdrive..... next step should be trans temp light coming on..... if it works......
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
OD is off when the lite is on, you realize? And if that happens, the tranny is getting too hot. As others have stated, start with removing the check valve.
Old 09-02-2012, 10:35 PM
bergoff's Avatar
bergoff
bergoff is offline
Is this what your taking about? Name:  2012-09-02_21-33-19_783.jpg
File Type: jpg
Old 09-02-2012, 10:40 PM
SilverSS's Avatar
SilverSS
SilverSS is offline
Yes that's where the check valve is.
Old 09-02-2012, 10:42 PM
zman17's Avatar
zman17
zman17 is offline
yep, remove that hose and drill the ball out with a 5/16ths drill bit, clean it out with some brakleen and blow it out with air and reinstall.
Old 09-02-2012, 10:59 PM
gdstock's Avatar
gdstock
gdstock is offline
WHile I had that line off, I would blow out the trans cooler part of radiator also.
Did you have crap in the bottom of trans pan?
Quick Reply: i have o/d then i lose it after a bit
