abs and brake light - abs control module ?
Old Sep 4, 2012 | 09:01 PM
Should be held in with a clamp, and bolt, very similar to the distributor.....
Old Jul 24, 2013 | 11:24 AM
fbenkautz's Avatar
fbenkautz
My ABS and brake light on, transmission shifts at 3000 RPM, Sensor didn't fix it.
Everybody says it is the sensors. Not so.
Old Jul 24, 2013 | 01:41 PM
Sooper's Avatar
Sooper
There are two sensors. Did you change both, or just one, and which one?
Old Aug 13, 2013 | 10:43 AM
fbenkautz's Avatar
fbenkautz
I keep seeing where you guys find the "magic bullet" ie. sensor in the differential or sensor in the transmission. I have done all that and more and still have the problem. Here is what I have done so far.
1. Replaced sensor in differential, clear, no metal shavings on it
2. Replaced sensor in transmission.
3. Completely cleaned battery terminals and all grounds.
4. followed wiring from rear sensor and transmission to engine, no opens
5. Checked level of brake fluid.
6. Replaced ABS controller (truck has rear ABS only).
7. Resistance on rear diff sensor 1.85 ohms.
8. Resistance on transmission sensor approximately 5 ohms.
Note: NAPA even had me try a second transmission sensor just in case.
I have run out of options. the ABS, brake, and check engine light is still on. I still get a P0500 code for speed sensor. The only thing left that I can think of is a broken wire somewhere.
I have worked in electronics and see that the engineers who drew up the wiring diagrams are mentally challenged at best.
Old Aug 13, 2013 | 10:56 AM
I will most certainly agree with your last statement.
No vehicle speed sensor input.
What year is your truck? Does your speedometer work?
Old Aug 14, 2013 | 11:51 AM
fbenkautz's Avatar
fbenkautz
2001 Dodge Ram 1500 5.9 engine.
No Speedometer, no Odometer, ABS, Brake, check engine lights on
Old Aug 14, 2013 | 10:43 PM
chandler_wellington's Avatar
chandler_wellington
I finally figured out my ABS/Brake light. I followed the service manual troubleshooting and this is what determined the problem:
RWAL DIAGNOSTIC PROCEDURES—TEST 6
This procedure starts with both the brake warning
lamp illuminated and ABS warning lamp illuminated and RWAL diagnostics cannot be performed.
If you are able to retrieve a DTC from the CAB's memory, then perform RWAL DIAGNOSTIC PROCEDURES
TEST 1.
1
Turn the ignition key to the OFF position.
Disconnect the 14-way RWAL CAB connector.
Turn the ignition key to the RUN position.
- Is the brake warning lamp illuminated?
YES
Perform step
2
NO
Perform step 8.
Step 2
Inspect the level of brake fluid in the master cylinder reservoir.
Is the fluid level correct?
YES
Perform step
3.
NO
Find and repair cause of leakage then perform the Verification Test.
Step 3
• Is the vehicle equipped with a diesel engine?
YES
Perform step 5.
NO
Perform step 4.
Step 4
Disconnect the harness connector from the differential pressure switch
Is the brake warning lamp still illuminated?
YES
Repair the short to ground for the brake warning lamp circuit and perform the
Verification Test.
NO
The pressure differential switch has shuttled. Check the
brake system for air in the hydraulic circuit or possible mechanical
damage. Repair as necessary and then perform the Verification Test.
I'll stop pasting there because that is where I found the trouble.
I took the little switch out from the pressure differential block (connected to the master cylinder) and moved the shuttle 'thing' that was grounding the switch and making the light come on. I moved the The shuttle 'thing' with a dental pick. I think there is an easier way but it worked for me.
I'm happy that those darn lights are finally off.
Hope this helps.
Old Aug 14, 2013 | 10:51 PM
chandler_wellington
Hopefully you will figure it out. It can be frustrating.
Old Aug 23, 2013 | 12:35 PM
jham0077's Avatar
jham0077
What is step 8? I've had this problem on the wife's truck for the better part of a year. Replaced sensors, goes off for a day, back on. Flushed fluid. It finally decided to stay on. The brakes work though, not sure about the ABS part. So, step 8? Or is this procedure posted online somewhere? Maybe I won't need step 8.
Old Aug 23, 2013 | 01:12 PM
oxymoron29's Avatar
oxymoron29
You mentioned the axle seals had been replaced. When I did my balljoints / u joints I had to remove both front wheel ABS sensors. When I finished the job I had the ABS/brake lights light up. Turns out I accidentally tweaked one of the front sensor brackets putting them back on the spindle so the magnet face was no longer parallel with the phonic wheel. All I had to do was bend one side further inward and the lights went out. Didn't think something so minor would set it off, but it did. Give this a quick check to make sure it's not something as daft as this.
