abs and brake light - abs control module ?
Old Aug 26, 2013 | 01:10 PM
  #21
jham0077's Avatar
jham0077
Well, no need for Step 8, "shuttling" the valve got the ABS light off. The BRAKE light is still on though. Fluid looks borderline low. Don't have any. Gotta put rear axle seals in it this afternoon, I think. The backside of the tire is grimy, didn't bother feeling it, figure it out when I get the tire loose.
Thanks to this site and it's members again!
Old Aug 26, 2013 | 01:54 PM
  #22
zman17's Avatar
zman17
Retired Moderator - RIP
Bad wheel cylinder I bet. It will also cause the lights.
Old Sep 28, 2019 | 12:11 PM
  #23
James Baltz's Avatar
James Baltz
Default I need step 8
Originally Posted by chandler_wellington
I finally figured out my ABS/Brake light. I followed the service manual troubleshooting and this is what determined the problem:
RWAL DIAGNOSTIC PROCEDURES—TEST 6
This procedure starts with both the brake warning lamp illuminated and ABS warning lamp illuminated and RWAL diagnostics cannot be performed.
If you are able to retrieve a DTC from the CAB's memory, then perform RWAL DIAGNOSTIC PROCEDURES
TEST 1.
1
Turn the ignition key to the OFF position. Disconnect the 14-way RWAL CAB connector.
Turn the ignition key to the RUN position.
- Is the brake warning lamp illuminated?
YES
Perform step
2
NO
Perform step 8.
Step 2
Inspect the level of brake fluid in the master cylinder reservoir.Is the fluid level correct?
YES
Perform step
3.
NO
Find and repair cause of leakage then perform the Verification Test.
Step 3
• Is the vehicle equipped with a diesel engine?
YES
Perform step 5.
NO
Perform step 4.
Step 4
Disconnect the harness connector from the differential pressure switchIs the brake warning lamp still illuminated?
YES
Repair the short to ground for the brake warning lamp circuit and perform the
Verification Test.
NO
The pressure differential switch has shuttled. Check the
brake system for air in the hydraulic circuit or possible mechanical
damage. Repair as necessary and then perform the Verification Test.
I'll stop pasting there because that is where I found the trouble.
I took the little switch out from the pressure differential block (connected to the master cylinder) and moved the shuttle 'thing' that was grounding the switch and making the light come on. I moved the The shuttle 'thing' with a dental pick. I think there is an easier way but it worked for me.
I'm happy that those darn lights are finally off.
Hope this helps.
I have no idea where you found this guide but I’ve been looking for the complete guide for hours now and no luck.
Old Sep 28, 2019 | 03:51 PM
  #24
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Fsm in the FAQ section
Old Jan 6, 2021 | 12:02 PM
  #25
Clifton Gardner's Avatar
Clifton Gardner
Default break light will light proportion valve and combination valve stick
Originally Posted by 98RamSledHauler
Hello. I bought a 98 Ram 1500 5.9 about 5 months ago. A couple months ago, the ABS and Brake light would stay on when I started the truck after driving it sometimes. Never comes on if it sits overnight on first start. Brakes seem to work fine, new front rotors and pads, backs have a little life left (problem did exist before fronts replaced).
I have read on this and replaced the rear speed abs sensor and cleaned the connections into the abs control module. I tried to have the abs codes checked, but was told due to the age they were unable to read any. Recently had front axle seals replaced and the mechanic did a small amount of looking and thought the abs control module had a relay that was "sticky".
I pulled a module from a 98 Ram (5.2) from local salvage (all they had for Ram in that year) but when comparing the white label values they are different than mine. So, my questions:
1. Are there differt control modules? Maybe a 2 wheel and 4 wheel?
2. If I can find the module with same label, can I simply just unplug my current module and swap them out, leaving battery disconnected for 30 minutes after replacement, or do I need to do more than this? Are there other years of Ram or possibly Dakota or Durango that would use same module?
3. Any other thoughts on what may cause this behavior?
Thanks for any input/advice!
i have had same problem, have found that abs system can stick or set in wrong position internally,abs will cut presure off to front or back brakes all togeather,be aware that it can even hold pressure on and cause break failure in all veihicals with this problem . this is a failer to reset to proper position internaly after any kind of bleeding or opening system. this can lock pressure in system and burn up calipers or drums and cause sever accidents
Old Jan 6, 2021 | 12:14 PM
  #26
Clifton Gardner
a lot of the break failer has been caused by combination valve and or proportion vavle will set and cut pressure or hold pressures on front or back brakes while driving . seal in real will go bad on axile and calipers also.
Old Jul 10, 2021 | 06:55 PM
  #27
smjeanson's Avatar
smjeanson
TEST 1.
1
YES
Perform step
2
NO
Perform step 8.
Step 2
YES
Perform step
3.
NO
Step 3
YES
Perform step 5.
NO
Perform step 4.
Step 4
YES
Verification Test.
NO
Hope this helps.
Found your post and started down the list and only made it to step 2 which in my case the answer is NO so I need to go to step 8. Do you have the rest of this diagnostic list or know where it is in the the service manual. I have the 98 factory service manual and I cannot find the Troubleshooting procedure you have mentioned in my copy.
Also, to confirm, should the parking brake be set during this test? I did it with the parking brake on first then off.
Old Jul 10, 2021 | 08:01 PM
  #28
Download the factory service manual for your truck from here.
