Power windows not working
Old Sep 8, 2012 | 12:27 AM
redhemi06's Avatar
redhemi06
ok so its gonna rain tonight, kinda started sprinkling when i did this but i took the door panels up and applied power to the motor using my handy dandy alligator clip jumper wires and theyre now up and the truck is locked for the night. since the fuse is good then im thinking when my battery fell over it may have pulled the power wire or ground for the switch? any thoughts?
Old Sep 8, 2012 | 12:45 AM
gdstock's Avatar
gdstock
Battery turned over? Yeah, maybe wire pulled loose in PDC underneath. Check schematic and see where power for windows goes in and out of PDC.
Old Sep 8, 2012 | 10:01 PM
redhemi06's Avatar
redhemi06
sure enough the wire pulled loose, thanks for the help!
Old Sep 12, 2012 | 07:37 AM
ReyesUSMC9's Avatar
ReyesUSMC9
Originally Posted by Sooper
The driver's switch has to be plugged in for the passenger switch to work. More than likely the harness plug slipped off the switch. This has happened to me in both my Ram and Durango.
You'll have to remove the panel, but just make sure the harness is plugged into the switch before you start replacing parts.
Thanks. I had this exact same problem with my 2005 1500 quad cab and the harnesses were on the switch real loosely. Don't know how they got like that but I push them in and moved the wires around a little bit and now the switch has full power. Thanks again
