broke a dist. cap bolt, how to fix PROPERLY
Old Sep 14, 2012 | 07:30 PM
redneck_ram's Avatar
redneck_ram
Default broke a dist. cap bolt, how to fix PROPERLY
well, my buddy picked up a 99 1500 sport yesterday, and today, wjile working on it, i broke a distributor cap bolt off in the distributor.
anyone have a fix for it? the proper way would be nice! if not, ill just use zip ties once i get the other bolt out, if it ever comes out.
Old Sep 14, 2012 | 09:03 PM
UnregisteredUser's Avatar
UnregisteredUser
I don't see why the proper way to do it would be any different just because it's in the distributor.
If it ever happens to me, I'm going to pull the distributor out and attempt to remove the broken fastener by unscrewing it -- I like to cut a slot for a screwdriver when possible, but have been known to use a fine punch or even a pick with a small hammer to coerce the broken fastener to turn until it can be gripped with pliers. Failing that a screw extractor (EZ Out) comes next. If all else fails it's Heli-Coil time, or maybe that cool thread repair epoxy stuff (Permatex P/N 81668 Stripped Thread Repair Kit).
Then it's off to get fuel sync put back to right... oh joy oh boy fun fun!
PS: Because they're prone to breakage, I always apply ye olde hammer of corrosion busting force and some penetrating oil to those fasteners before trying to remove them. So far, so good.
Old Sep 14, 2012 | 09:35 PM
It's Me Patt's Avatar
It's Me Patt
Your looking for the "proper fix" but you'll use zip ties to rig it? ez outs s**k!
Old Sep 14, 2012 | 09:51 PM
redneck_ram
well of.course! i dont have a right angle drill atm. so zip ties will work for now. lol
Old Sep 14, 2012 | 10:12 PM
It's Me Patt
Yup pretty much a PITA to work on with it still in the truck..I just snapped off a bolt on my pressure washer and that's a PITA, so I feel for ya..good luck! PB blaster is your friend..ez-out enemy
Old Sep 15, 2012 | 07:14 AM
Dist cap bolts are tiny, and the part of the dist they go thru is fairly thin..... might be able to grab it from the bottom, and thread it out that way. Of course, doing that while the dist is in the truck is gonna be damn near impossible....... Just mark where every points before you take it out, and don't move anything till you get it back together.
Old Sep 16, 2012 | 11:35 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Redneck was at my house yesterday, while he was here his friend back home pulled the dizzy without marking anything. Ouch.
Old Sep 16, 2012 | 11:37 AM
Ooops. Bad plan.
Old Sep 17, 2012 | 02:31 PM
zman17's Avatar
zman17
Ooops. Bad plan.
Seems they got it back together ok. I'll do the fuel sync after they get some other issues fixed.
Old Sep 17, 2012 | 04:36 PM
redneck_ram
yep new dizzy, got it back in to where it was. i have a pretty good at remembering where things go just by looking at them before removal. new fuel rail, and injectors going in shortly!
1200 dollar truck is turning into a 2k dollar truck pretty damn quick.
