no spark/no start
Old Sep 16, 2012 | 01:55 PM
blackfootball1's Avatar
blackfootball1
with coil grounded, still no start. is there anyway to test a pcm? can a dealer test them?
Old Sep 16, 2012 | 01:57 PM
blackfootball1
the crank sensor was installed after the motor was installed.
Old Sep 16, 2012 | 02:10 PM
It's Me Patt's Avatar
It's Me Patt
http://dodgeram.org/tech/gas/Trouble/Fault-42.htm
Old Sep 16, 2012 | 09:26 PM
blackfootball1
can not pull codes from PCM when scanner is hooked up scanner goes blank when key is turned to run position. is there a way to wire around asd or pcm, not to drive but to just to test...
Old Sep 17, 2012 | 09:36 AM
Check and see if you are getting power to the coil while cranking. (can test the injectors instead, may or may not be easier, ASD supplies power feed to both)
Old Sep 17, 2012 | 03:02 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Download the FREE service manual from the FAQ/DIY section and start tracing wires. And would you PLEASE add ALL the info about your truck to your sig AND profile.
Old Sep 17, 2012 | 05:45 PM
blackfootball1
Thank you all for the help!!! it had a bad ground wire off the PCM, fixed wire and she started right up!! again thank you all...
Old Sep 17, 2012 | 06:07 PM
It's Me Patt
Awesome man glad you got it fixed up & running!
