no spark/no start
Old Sep 15, 2012 | 07:33 PM
blackfootball1's Avatar
blackfootball1
Default no spark/no start
hello everyone i am new here so please bear with me.. i have a 1996 ram 1500 5.2 V8. i replaced the crank and bearings in it and reinstalled the motor into the truck. after all wireing was hooked back up the ASD relay was clicking very fast. after unhooking the wires off both O2 sencers they would stop.. when tried to hook computer up to data link computer blacks out when the key is turned on.. could someone give me some ideas have racked my brain for 4 days now....
Old Sep 15, 2012 | 09:53 PM
blackfootball1
have replaced the cps already. could the asd still be the problem and if so why would the O2 cause the relay to click ?
Old Sep 15, 2012 | 09:58 PM
It's Me Patt's Avatar
It's Me Patt
PCM could be shot..could have messed up the coil--->and no spark..does it crank?
Old Sep 15, 2012 | 10:03 PM
gdstock's Avatar
gdstock
Check the numerous grounds. Battery to engine, batt to fender, batt to frame. Then firewall to right head. Make sure they are all clean and tight.
Old Sep 15, 2012 | 10:33 PM
redneck_ram's Avatar
redneck_ram
check BOTH grounds on the power steering bracket. will cause the asd relay to click if one isnt hooked right. also will cause a no spark situation, and no bus errors.
Old Sep 16, 2012 | 02:42 AM
Jason_Dodge's Avatar
Jason_Dodge
1+ on that.
Old Sep 16, 2012 | 08:01 AM
blackfootball1
yes the truck cranks fine just no spark.
Old Sep 16, 2012 | 08:06 AM
blackfootball1
i will check all grounds again.. when checking the coil for volts i noticed both wires were hot. and the PCM grounds the coil if i am correct. but still not sure why data link goes dead when key is turned on, will ground issue cause this?
Old Sep 16, 2012 | 10:23 AM
It's Me Patt
Please post your results...Patt
The PCM grounds the coil side of the relay through terminal number 85
https://dodgeforum.com/forum/1992170-post14.html
Old Sep 16, 2012 | 12:06 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Did the crank sensor get installed after the motor was in? If not make sure the wire is not pinched between motor and trans housing.
