99 dodge ram 1500 pu quad cab v8 5.2L
Old Sep 17, 2012 | 08:56 PM
ddganey's Avatar
ddganey
Default 99 dodge ram 1500 pu quad cab v8 5.2L
Fuel pump 07/12, crankshaft sensor, fuel pump relay, new battery. Truck quit 8/4, won't crank, tune-up 12/10, don't drive lots, disabled. Today, brother-in-law said it wasn't getting fire or gas, can someone please help me figure out the problem, haynes manual not much help.
Old Sep 23, 2012 | 10:37 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I will move your post to the 2nd Gen Ram section.
Old Sep 23, 2012 | 10:42 PM
gdstock's Avatar
gdstock
Doesn't make much sense. I suppose these are dates things were done?
Any codes? Gotta have fuel, spark, and air. Swap a realy with the ASD relay. What is fuel pressure? Need to be 45 to 50 psi. Pull plug wire off and crank to see if you have fire.
What was done on tune up?
Old Sep 24, 2012 | 09:30 AM
It's Me Patt's Avatar
It's Me Patt
sounds like your going long periods without a start/drive..when you say no crank I'm taking that as nothing when you turn the key..which should rule out fuel..I would say even if you put in a new bat, either something drained it and/or something is up with your alternator..you can pull it and have it tested at you local part store and go from there..post you findings
Old Sep 24, 2012 | 01:57 PM
ddganey's Avatar
ddganey
Truck has no codes/no check engine, so I'm confused? Yes, completed repairs. Switched relays, new fuel pump relay, & used dialectric grease. Brother-in-law put ohmmeter on crankshaft sensor, no fuel/fire. Maybe electrical, unsure. Old fuel pump was 40 psi. New fuel pump from autopartswarehouse.com 07/12, worked 3 weeks, now it won't crank at all, new battery 5/12 also. Turns over but won't crank.
Old Sep 24, 2012 | 02:01 PM
ddganey's Avatar
ddganey
Tune-up = plugs/plug wires/distributor cap. Truck has no codes/no check engine, so I'm confused? Yes, completed repairs. Switched relays, new fuel pump relay, & used dialectric grease. Brother-in-law put ohmmeter on crankshaft sensor wire, no fuel, or fire. Maybe electrical, unsure. Old fuel pump was 40 psi, new fuel pump from autopartswarehouse.com 07/12, worked 3 weeks, now it won't crank at all, new battery 5/12 also. Turns over but won't crank.
Old Sep 24, 2012 | 02:06 PM
It's Me Patt
I'm guessing you mean it cranks but won't start? Do you check pressure on the installed pump? Test the coil? Volts on new bat?
