Belt squeeling
Old Sep 20, 2012 | 06:06 PM
Derick C.'s Avatar
Derick C.
Default Belt squeeling
The belt only seems to last 2 weeks before it starts squeeling. Never had a problem before I built the 408. All the local parts stores stock are gates belts, 2 part #'s, I have tried 2 of each.
Old Sep 20, 2012 | 06:34 PM
Hahns5.2's Avatar
Hahns5.2
Make sure the crank pulley isn't loose. I ran into some belt squealing after I rebuilt my motor, it turns out the pulley worked it's way loose yet it wasn't visibly wobbly while running.
Old Sep 20, 2012 | 06:45 PM
Matt Nickerson's Avatar
Matt Nickerson
My Gates belt and Dayco belt both squealed...switched to a Gatorback and now no squeal.
Old Sep 20, 2012 | 06:54 PM
95RAM360's Avatar
95RAM360
Mine had a squeel because i had gunk built up on my idler pulley...cleaned it and it stopped the squeak
Old Sep 20, 2012 | 07:40 PM
Derick C.'s Avatar
Derick C.
Crank pulley is tight. I replaced the tensioner pulley and idler pulley when I built the motor. I just ordered a gatorback belt today when I was at work so we will see if that fixes it.
Old Sep 20, 2012 | 08:06 PM
Mine didn't squeal but made a sound like a gazillion crickets chirping...I just replaced it with a gatorback last weekend. No sound at all now.
Old Sep 20, 2012 | 08:07 PM
It's Me Patt's Avatar
It's Me Patt
It's recommended that belt replacement is done with the new tensioner. Not to mention belt type/brand make a difference. I did the same thing, new tensioner old belt. New idler pulley, still noisy. Then bought the 'better' belt and a few rides later it started making noise again..long story short, several belts (brands) later I buy the 'cheap o' and quiet as can be
Old Sep 20, 2012 | 08:53 PM
If you just replaced the pulley, might wanna replace the tensioner arm as well...
Old Sep 20, 2012 | 09:37 PM
It's Me Patt
thought it comes as a non serviceable assembly?
Old Sep 20, 2012 | 09:51 PM
SilverSS's Avatar
SilverSS
My Gates belt squealed like crazy. Put on a Dayco and it's quiet.
