Belt squeeling
Old Sep 20, 2012 | 10:44 PM
Derick C.'s Avatar
Derick C.
If you just replaced the pulley, might wanna replace the tensioner arm as well...
The tensioner arm still has alot of tension. When I put the motor in it got the 2 new pulleys and a new belt at the same time.
Old Sep 20, 2012 | 11:38 PM
It's Me Patt's Avatar
It's Me Patt
Might want to order one from rock auto use discount code 110502559063811
Old Sep 20, 2012 | 11:48 PM
keepitrunning's Avatar
keepitrunning
I removed the tensioner assy and gently pryed the bearing seals out , rinsed bearing out and re-greased with needle fitting on grease gun. Seals back in and no squeal.
Old Jul 28, 2013 | 11:38 AM
Derick C.'s Avatar
Derick C.
Turns out with my scat crank the balancer wont press on all the way so the belt was squealing on the lower pulley. Had to mill of 1/8" on the back of balancer.
