Throttle Body Mod
Old Sep 20, 2012 | 09:33 PM
MeanMagnum99's Avatar
MeanMagnum99
Default Throttle Body Mod
Hey fellas as most if you know I just did a serious top end build on my truck. Well even though I've been tuned since my cam, heads, and every thing else Ive done to her running it she's running super rich. I will admit that right now I have the stock TB on until my new 52mm from hipotek shows up. I have my idle set screw turned in so far that my iac steps are at 2-10. If I were to drill a tiny hole in each plate to help get air past the plates easier and to give my iac some relief would it help? Even though the plates are cracked I'm still running rich.
Old Sep 20, 2012 | 09:50 PM
It's Me Patt's Avatar
It's Me Patt
How soon till the new TB arrives? I'd take a dremel to the edges..would think that would allow for better/extra flow..my 3
Old Sep 21, 2012 | 06:36 AM
MeanMagnum99
It's almost a week out. I didn't think of that and I do happen to have a new dremel that rarely gets used. Thanks for the advice!
Old Sep 21, 2012 | 08:12 AM
The computer determines mixture. If you artificially add more air, the computer will simply compensate by adding more gas. How old are your O2 sensors?
Old Sep 21, 2012 | 08:29 AM
Ugly1's Avatar
Ugly1
There are probably less destructive ways to create a vaccum leak to see if it helps but I think you may be heading down the wrong path. You ought to give Hemifever a call if you are running rich.
Old Sep 21, 2012 | 08:38 AM
MeanMagnum99
Voltage is good, idle mixture is actually fine. It's just when I get out if it is when it wants to stumble and die unless I turn the TB set screw in really far like it is now.
Old Sep 21, 2012 | 08:39 AM
MeanMagnum99
So far Sean has sent me 3 tunes and all have been too rich. Plus I think Sean is getting tired of messing with my truck.
Old Sep 21, 2012 | 08:50 AM
Ugly1's Avatar
Ugly1
You may need to find yourself a wideband O2 setup to gather the most accurate data to send to Hemifever.
Old Sep 21, 2012 | 02:47 PM
ryan0714's Avatar
ryan0714
not to be mean but its kinda his job to send you tunes. as said above gettin a good mixture reading would be best bet.
Old Sep 21, 2012 | 03:02 PM
merc225hp's Avatar
merc225hp
Got a vac gauge kicking around? put it on and see what you are pulling. Is the post 02 hooked up yet?
