Shudder
Old Oct 1, 2012 | 10:49 AM
  #21
It's Me Patt's Avatar
It's Me Patt
"A lockup converter will have a clutch disc inside of it (much like a manual transmission) which, when the torque converter is "flooded" with tranny fluid, will lock up (same as taking your foot of the manual trans clutch pedal.) To flood the torque converter, fluid needs to get into the converter at a much higher rate. To do so, a Torque Converter Clutch (TCC) solenoid inside the valve body of the trans opens a plunger which creates an additional fluid path that "floods" the torque converter with additional tranny fluid...locking up the clutch mechanism inside the torque converter".
Can anyone tell me exactly what "path" this is and can it be restricted enough to cause the shudder issue..and/or is this what TC shudder is/and caused by? Thanks
Old Oct 1, 2012 | 12:35 PM
  #22
jondakotaguy's Avatar
jondakotaguy
I'm going to be honest I have no clue; I'm to the point; i'm going to replace my mounts and then call it done; I'm not dropping any more time money or energy into this truck unless some finds the absolute fix/problem for the off idle shudder.
See you around pat. Let me know if you make any progress.
Old Oct 11, 2012 | 06:37 PM
  #23
jondakotaguy
Been a little while; hope your still making head way; Wife totaled her Jeep Gran Cherrokee.. there is absolutely nothing in there to stop damage i swear.. Cheap cheap cheap..
Old Oct 11, 2012 | 07:17 PM
  #24
Nereaga's Avatar
Nereaga
Hope she is ok!
Old Oct 11, 2012 | 08:16 PM
  #25
jondakotaguy
Yeah she is; the Jeep is not.. She was a little shaken up that's about it.
Old Oct 12, 2012 | 01:00 PM
  #26
Wh1t3NuKle's Avatar
Wh1t3NuKle
I didn't pick up on it if you mentioned it, but what are your symptoms? What you've quoted the last couple posts seems like it would manifest while cruising at least 60mph and then the "shudder" would be seeing the tach show a flare. Meaning the engine rpm would increase/decrease from 100 to 200 rpms. This would be less frequent on flat, but more frequent on slight grades/slope.
Anything like that happening?
Old Oct 13, 2012 | 11:14 AM
  #27
It's Me Patt
No it's just the oppsite. Doesn't happen grade/slope/hills and does on flat ground. The reason being when I hit a hill I'm getting more line pressure and an increased rpm. The shudder begins at 40mph and the flare will happen, lets say I'm at 42mph and take my foot off the accel ped, then when I hit the ped again it flares (decrease in rpm)..as long as the rmp is above approx 1400 it won't shudder at the 40-50mph range...I did adjust the TV cable and altered the shift points and increased line pressure but didn't like the harsh kick/high revs..not trying to burn up the trans/converter..
Old Oct 13, 2012 | 09:38 PM
  #28
jondakotaguy
IDK when I did mine; i've already seen increased power and 2.4+ MPG increase.
Which is alot.
but what your describing as far as RPM drop sounds normal; being you will see a small increase in intial vacume when you open the throttle; then a decrease untill it builds back up?
Also not to go off topic we got the wife a New Hundai.. (she works at the dealer so.. no american for her i guess LOL)
Old Oct 13, 2012 | 10:00 PM
  #29
It's Me Patt
Which is alot.
Foot off the ped then back on the ped shouldn't cause an rmp drop? give it gas rpm goes up..it's not minor either..I have to get it to kickdown to not drop off like that..anyways she's ok and gets a new ride, win-win!!
Old Oct 15, 2012 | 08:49 AM
  #30
jondakotaguy
In a Ford I would say no.. but on this kegger mod it seems if you look around most people say it's normal being it's in direct correlation of vacuum drop (which is normal)
I guess it all depends how much it's dropping.
