Air in the system does a couple of things. Dirst, it allows moisture to remain in system whcih turns to acid, and it prevents the refrigerant from being filled to the correct level and has different compression proerties than the refrigerant.
You can recharge it, but it's a waste of time if you don't evac the air/moisture out. It'll contaminate the refrigerant, corrode components, and eventually cause leaks.
