So let's say I want to change gears
Old 10-12-2012 | 02:12 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by Wombat Ranger
Gears + install kits can be had for $300 per diff. $600 total parts investment if carriers are re-used.
Disagree completely. Feel free to link to said parts to "tell me off".
Old 10-12-2012 | 02:55 PM
jpsycoboy5's Avatar
jpsycoboy5
Yeah if you can post up links ill jump on those right now
Old 10-12-2012 | 05:43 PM
Wombat Ranger's Avatar
Wombat Ranger
Well, I don't shop for pansy parts (1/2 ton stuff) so here's what's on my shopping list for gears.
Front
http://www.drivetrainamerica.com/p-8...set-thick.aspx
http://eastcoastgearsupply.com/i-717...sco-94-98.html
Rear
http://eastcoastgearsupply.com/i-126...ster-rear.html
http://eastcoastgearsupply.com/i-717...88-motive.html
I have a 4.56+ 30 spline detroit, so I will only need one thick cut gear set.
Total there is $620. I would think that 44 parts should be even cheaper, and 9 1/4's I don't know about.
Old 10-12-2012 | 06:13 PM
Hylander7's Avatar
Hylander7
Don't know about buying parts seperate, but I just got quotes from a few local shops.
Regear to 4:10's with new bearings and seal and carrier for the front.
OTD: $1200
Old 10-12-2012 | 11:19 PM
dhvaughan's Avatar
dhvaughan
for both axles? that's pretty cheap.
what brand gears and bearings?
Old 10-13-2012 | 01:28 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Just like you to not be on topic.
Some links I scrounged up for the half tons.
9.25
http://eastcoastgearsupply.com/i-128...it-master.html
Randys showed like out of stock $850 for R&P!!
D44
http://eastcoastgearsupply.com/i-126...it-master.html
http://eastcoastgearsupply.com/i-153...4-carrier.html
http://www.ringpinion.com/b2c/Produc...rce=DiffWizard
@Hylander -- Git R Dun and good luck. Shopping around helps. Thanks for inquiring earlier.
Front
Rear
Old 10-13-2012 | 01:36 AM
Wombat Ranger
Seeeee I told you it could be done for not toooo much moolah...
Old 10-13-2012 | 01:43 AM
Hylander7's Avatar
Hylander7
Both axles
No idea what brand
Old 10-14-2012 | 12:12 AM
newman1367's Avatar
newman1367
Originally Posted by Ham Bone
Converting to a 2500 would be neat but I don't wanna mess with going from 5 lug to 8 lug.
Basically I want bigger tires, but not crazy, and to re gear to gain back performance similar to stock.
Well that answers your question!
No sense holding out for a 5 lug dana 60
