ecu issues 2000 ram 5.2
Old Oct 15, 2012 | 03:01 AM
tombomb661's Avatar
tombomb661
Default ecu issues 2000 ram 5.2
Hey guys! My buddies band van needed a new ecu as it was cutting out most likely from heat. It's a 2000 dodge ram van 2500 with a 5.2.
I put a programmed refurbished ecu in and it ran great. For about 15 minutes. Then it started stalling out whenever the gas pedal was released. it would run like crap as well.
For kicks, I put the old ecu in and it runs just fine. Swapped it out again amd the fuel pump would not kick on. There was also a delay in the dash lights turning.on.
So guys, does it sound like this business sent a badly refurbished ecu?! Please help. they are leaving for tour on Friday
Thanks in advance everyone!
Old Oct 15, 2012 | 04:02 PM
tombomb661's Avatar
tombomb661
Bump.
Old Oct 16, 2012 | 07:47 AM
tombomb661's Avatar
tombomb661
Ok....
Can you guys tell me if an ecu from a 2000 dodge pickup with a 5.2 work on a 2000 ram van 2500 with a 5.2?
Getting despwrate here...
Old Oct 16, 2012 | 12:39 PM
It's Me Patt's Avatar
It's Me Patt
Should but it needs to be reflashed..
Old Oct 17, 2012 | 06:43 AM
tombomb661's Avatar
tombomb661
Alrighty. It's one of the guys trucks. So I can't do that. I'm assuming it was a bad refurbed ecu. I haven't gotten any backup on it but I think tjats what happened. W
tombomb661's Avatar
tombomb661
Would the van not run if I put that ecu in?
Old Oct 18, 2012 | 10:58 AM
It's Me Patt
So why take it out in the first place? And why not put it back in?
Old Oct 19, 2012 | 03:13 AM
tombomb661's Avatar
tombomb661
Yeah. It was a test to see if it was the new ecu or not. After the car gets warm and is in traffic, it dies and doesnt start back up for sometimes up to four hours. Thats what happened to the guys last night.
Got another ecu, same issue again. They state that they are pre-programmed ecus. Is there any particular procedure??
Old Oct 19, 2012 | 04:08 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You are removing the negative battery cable first right? And what brand rebuilt is it?
Old Oct 23, 2012 | 04:18 PM
tombomb661's Avatar
tombomb661
I actually did not to that. I know I should have but I didn't disconnect putting the old one back in.
All computer resources is the company
