new air intake/new noise
Old Oct 15, 2012 | 07:06 PM
nvrsftram's Avatar
nvrsftram
Default new air intake/new noise
hey everybody, just installed a new air intake on my 01 ram sport 5.9, took it for a drive and i have a loud whistling noise when i take off fast or so, if i have it in neutral and rev the engine it does not do it, almost sounds like a diesel engine when they step on the on it, hopefully it just the increased air flow, and the fact that i removed my under hood insulation that was falling down. any advise would be great thanks
Old Oct 15, 2012 | 07:09 PM
stewie01's Avatar
stewie01
What kind of air intake did you install?
Old Oct 15, 2012 | 07:13 PM
kejobe's Avatar
kejobe
^^^ that plus make sure the gasket is in place inbetween the throttle body and the intake and that the intake is fully seated.
Old Oct 15, 2012 | 07:45 PM
Mr. MonaVie's Avatar
Mr. MonaVie
Did you check to make sure all the bolts were tightened down after you drove it a bit?(after installation)*
Old Oct 15, 2012 | 08:24 PM
nvrsftram's Avatar
nvrsftram
Thanks for the replies, the intake was a knock off one off ebay, suppose to be an aem replica, but instead of the cheap filter they sent i had a k&n filter the same size
Old Oct 15, 2012 | 08:33 PM
kejobe's Avatar
kejobe
If its seated and sealed properly, it may be something youll have to live with if you want it on there. I put a 14x3 on a few weeks ago, even knowing about the noises, but took it off last week. The sucking sound at throttle didnt bother me. The whistling did and got annoying quick.
Old Oct 15, 2012 | 08:59 PM
nvrsftram's Avatar
nvrsftram
yup, probably just have to deal with it, at least it take my mind off all the other noises it makes, haha.
Old Oct 16, 2012 | 12:26 AM
mibzzer15's Avatar
mibzzer15
Mine had a whistling noise when i was giving it throttle when i first bought the truck...turns out there was no gasket between the air box and TB....added one in there and sounds great now. you may want to check that.
Old Oct 16, 2012 | 03:03 AM
dlallen66's Avatar
dlallen66
On my 99 I removed all the stock air cleaner stuff and installed an open 9 inch round filter directly atop the Throttle Body and I got some noise but nothing that really bothered me. When I bought the truck I discovered the whistling noise was the gap between the air box and throttle body because the gasket was missing.
Old Jan 7, 2013 | 11:10 PM
tot64's Avatar
tot64
So the whistling whenever I give it a little gas is a gasket? Anybody know where to get one of those? Btw, sorry if this thread is done or somethin
