oil pressure light/low idle
Old Oct 15, 2012 | 10:36 PM
mike.97.2500's Avatar
mike.97.2500
Default oil pressure light/low idle
ok so iv been searching for answeres here looking through older posts but cant seem to see anything like my problems. first off i have a 97 2500 4x4 5.9l gas new motor with 1800 miles on it. new oil pump, new oil pressure sending unit.
so i start my truck while the motor is cold and warming up to temp my oil pressure reads normal and no light comes on. once at temp the oil pressure guage moves while accelerating and at idle while stopped it drops and the light comes on some times the needle drops a little some times all the way down like it was off. now at idle in drive my rpms read about 6-700 always. when the needle drops and the light comes on i can touch the gas and add another 200 rpm the pressure jumps up to normal and the light comes off. at idle in gear when the pressure drops and the light comes on i can put it in park the idle jumps to about 7-800 and the pressure comes up and the light goes off. is my idle too low? is there away to adjust this or do i need to have the fuel sync done? i never did the sync when i put the motor in. just did tdc on #1 set the dist and dropped it in fired right up and have no back fires or anything but will admit at times i think it feels sluggish.
kind of stumped here its scary to see the pressure drop and the light come on but i hear no bad sounds always sounds normal and never feels funny either. any and all advice and help is greatly appreciated.
Old Oct 16, 2012 | 10:50 AM
It's Me Patt's Avatar
It's Me Patt
It's normal for the oil pressure to fluctuate when driving. Min idle pressure is approx 40-41psi. Have to ask you have checked the oil level when it's cold and been sitting for a bit? Have you had any codes? And yes the idle is to low and will cause the low oil pressure..
Old Oct 16, 2012 | 08:56 PM
mike.97.2500
oil level is fine i check it religously(sp) since the new motor was put in. i get one code periodically for a evap leak nothing to do with oil just a leak in my tank im too lazy to fix lol. so how would i fix the low idle? will doing a fuel sync fix that? or is there something else i need to do? and i have a scan tool i bought from the cornwell guy at work would that do the fuel sync? or do i need something from the dealer?
Old Oct 16, 2012 | 09:28 PM
gdstock's Avatar
gdstock
Originally Posted by mike.97.2500
oil level is fine i check it religously(sp) since the new motor was put in. ..........and i have a scan tool i bought from the cornwell guy at work would that do the fuel sync? or do i need something from the dealer?
Did it come with a manual? WIthout knowing what the scan tool is, not much way we can know if it will set fuel sync.
Old Oct 16, 2012 | 09:31 PM
UnregisteredUser's Avatar
UnregisteredUser
Fix your evap leak.
Old Oct 16, 2012 | 10:28 PM
mike.97.2500
i cant think of the name off hand ill look at it tomorrow and yes theres a manual ill look in there tomorrow also. and i guess ill be dropping the tank soon to fix my leak i have been thinking about doing my sending unit sick of not knowing how much gas i have lol might as well get it all fixed
