Any Advice?
Old Oct 31, 2012 | 04:55 AM
93grandzj's Avatar
93grandzj
probably blew the cap and rotor. fried mine on the 93 grand i had. no start and shut off while driving. check under the cap and look for signs of wear and build up of corrosion, check rotor too. that can happen if to long between preventative maintenance. the next part under them would be your sensor to replace.
Old Oct 31, 2012 | 04:30 PM
MarkM32's Avatar
MarkM32
Spark comes from the coil into the top of the dist. cap. If this is the case, check the plug on the bottom of the coil, you can also get a visible spark tool and crank it and see what color it is. Bright blue/white is what you want. If you've got that, check out the crank position sensor.
Old Nov 2, 2012 | 12:00 PM
Tess2012's Avatar
Tess2012
I replaced the crankshaft position sensor and started right up!
