Front wheel beerings
Old 10-22-2012, 09:25 PM
BigBlue83's Avatar
BigBlue83
BigBlue83 is offline
Default Front wheel beerings
hey guys! i havent been on in a while. got my transmision rebuilt about three to 4 months ago. havent really driven my truck in the last three months though. long story, that ill leave out for now because this is the tech section. I need to replace the wheel bearings in my passenger side. ive searched on here didnt really find a write up or anything.
so ill ask...
do i have to repace the whole hub or can i do just the bearings?
do these have to be pressed in?
i cant seem to find my haynes. any help that anybody could offer would be greatly appreciated.
i get to start driving my truck again in two weeks, i cant wait!!!
Old 10-22-2012, 09:53 PM
Matt Nickerson's Avatar
Matt Nickerson
Matt Nickerson is offline
Your truck is a 4x4 correct? All 4x4s have unit hub assemblies meaning the bearing is a part of hub. So no replacing bearings...
aofarrell2's Avatar
aofarrell2
aofarrell2 is offline
Hub and bearings are usually one unit that get replaced together on the 4wd models... When I priced them out they were around $200/ea, and I can't remember whether there was a core charge or not, probably was.
Old 10-22-2012, 10:00 PM
VEETEN's Avatar
VEETEN
VEETEN is offline
Similar procedure here>>> https://dodgeforum.com/forum/dodge-c...placement.html
But stop after removing the hub.
There are more posts on this I'm sure, but this is just one of my favorites.
Try using quotes around your search term "replace hub bearing"
And as others said 4x4 is hub/ bearing unit. ABS front is $$$$$$ but I doubt you have fronts in a 98
Old 10-22-2012, 10:05 PM
QuadCabLuv's Avatar
QuadCabLuv
QuadCabLuv is offline
2wd are also units, you havr to replace the whoe hub. Ive bought a couple on ebay for $70 a piece new amd was happy with them. But I packed them with grease really well cause they just didnt seem to be greased well enougj out of the box
Old 10-23-2012, 12:57 AM
ReadRam's Avatar
ReadRam
ReadRam is offline
On a 99 2wd the bearings are replaceable.
Old 10-23-2012, 02:01 AM
elecshoc's Avatar
elecshoc
elecshoc is offline
I've replaced just the bearings on my 96 as well.
Old 10-23-2012, 01:29 PM
aofarrell2's Avatar
aofarrell2
Are they? I didn't know that... I thought 2wd were separate... Or maybe some aftermarket ones are.
Old 10-23-2012, 01:33 PM
Countryboy_4_life's Avatar
Countryboy_4_life
Countryboy_4_life is offline
penetrating fluid will be your best friend. spray those studs going through the spindle to the hub good.
Old 10-23-2012, 01:58 PM
QuadCabLuv's Avatar
QuadCabLuv
Maybe its just the 2000-01 that are units.
Quick Reply: Front wheel beerings
