Check engine light fixes.
Old Nov 5, 2012 | 01:13 PM
rthompson's Avatar
rthompson
Default Check engine light fixes.
So I did the on off trick and got these codes. Any idea how to fix it so I can get that damn light off my dashboard?
23** Intake air temp sensor voltage too high or low Intake air manifold temperature sensor is out of range. Check sensor.
33* AC clutch relay circuit Short or open in the AC clutch circuit.
Old Nov 5, 2012 | 01:51 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Check the sensors and replace if needed.
Old Nov 5, 2012 | 01:59 PM
Gotta fix the problems to clear the codes to get the light to turn off....
Old Nov 5, 2012 | 10:54 PM
Matt Nickerson's Avatar
Matt Nickerson
Inspect the IAT sensor and connector. Probably just have to get a new one.
Get a wiring diagram for the ac circuit, Hanes might have it in their manual or download the FSM from the FAQs section, and trace the connections; look for bad wires, test relays and fuses, and pin down the short/open.
Then clear the codes and hope its fixed
Old Nov 6, 2012 | 10:54 AM
It's Me Patt's Avatar
It's Me Patt
Don't forget to do so (pull/replace) with the neg bat cable off. And that will reset the CEL too...
Old Nov 6, 2012 | 01:20 PM
rthompson's Avatar
rthompson
All the auto places around here do not have a new one in stock (IAT) so I will pull the old one off and clean it up good see if that fixes it. IF not then order one I guess.
Old Nov 6, 2012 | 03:22 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I don't think cleaning will do jack. Order a new one. And as stated, remove the neg. battery cable first.
Old Nov 6, 2012 | 07:42 PM
dhvaughan's Avatar
dhvaughan
voltage too high indicates that its shorted out, outputting a 5 volt or 12 volt signal.
replace.
reset pcm by removing battery cable and turning on headlights for 30 seconds to drain the capacitors. removing cable only for 5 minutes is not enough to reset it.
