Door buzzer
Old Nov 6, 2012 | 10:12 PM
97ramrod1500's Avatar
97ramrod1500
Default Door buzzer
How can I bypass this? It's so annoying and I'm sick of it!
Old Nov 6, 2012 | 10:16 PM
gertie240's Avatar
gertie240
I read a thread about a plug in the column you can disconnect, try searching that door chime, I havent tried it
Old Nov 6, 2012 | 10:17 PM
gertie240's Avatar
gertie240
or just pull the door switch out and unplug
Old Nov 6, 2012 | 10:22 PM
If you figure out how to make it stop, let me know because I want to make mine work.
Old Nov 6, 2012 | 10:30 PM
crazzywolfie's Avatar
crazzywolfie
just search. the info is out there if you look around here. i know someone even took some pics of what you have to unplug from your ignition switch to make the buzzer stop buzzing with the keys in the switch.
Old Nov 6, 2012 | 10:52 PM
gertie240's Avatar
gertie240
here is a link to the post we were talking about, and do I get to ask if your plenum is fixed? https://dodgeforum.com/forum/2nd-gen...w-picture.html
Old Nov 6, 2012 | 10:54 PM
kejobe's Avatar
kejobe
This??
https://dodgeforum.com/forum/2nd-gen-ram-tech/333520-how-to-disable-door-buzzer-w-picture.html
Old Nov 7, 2012 | 12:05 AM
dhvaughan's Avatar
dhvaughan
remove the covers around the column.
unplug the 2 wire electrical switch from the ignition.
do not molest the CTM, the little black box where the chimer lives (00-01).
do not remove fuse from pdl or pw (can't remember which) that powers the CTM, which powers all things with timers, including intermittent wipers.
