cant stop shaking(long post) really need help
Old Nov 13, 2012 | 07:43 PM
  #31
cutthroatxxx's Avatar
cutthroatxxx
Ok so the u joints seem fine,the ball joints seem fine I rotated the tires still feels the same pretty much it feels like I feel every bump in the road.Rear drive shaft is tight the front has a very small of left to right play before I rotate it...is that normal?I'm lost her.
Old Nov 13, 2012 | 07:48 PM
  #32
Wh1t3NuKle's Avatar
Wh1t3NuKle
Have you tried just taking out front drive shaft and see if the issue goes away? Be sure to mark with pen or scribe before removal so you its installed the same.
Old Nov 13, 2012 | 08:39 PM
  #33
cutthroatxxx
No I haven't just wasn't sure if that was normal maybe I should go pull it.
Old Nov 13, 2012 | 08:58 PM
  #34
ReadRam's Avatar
ReadRam
Did you jack up front end and check wheel bearing hub assembly for any play yet?
Old Nov 13, 2012 | 09:03 PM
  #35
cutthroatxxx
Yes nothing
Old Nov 15, 2012 | 02:01 AM
  #36
cutthroatxxx
A.s.a.p. I need to know the correct operation of the draglink&pitman arm where they meet.My draglink will turn left to right picture a motorcycle throtle....that type of motion&the*pitman*arm *will go left to right &move with it but it seems like its off,I thougt the pitman arm didn't swivel as it moved the draglink..but Im not sure that's Why I ask...also the*bushing *looks shot when you work it grease comes out.
Old Nov 15, 2012 | 02:04 AM
  #37
cutthroatxxx
A.s.a.p. IBEFORE I forget...I took if out for another ride& can tell 100% for sure its coming from the front feels like It feels every bump in the road in the area around the geae box I'm gonna say it's starting to seem like more of a rough ride then a shaking
..I think the shake is coming from whatever is bad or loose when I hit the bump in the road isn't absorbing it&making it vibrate
Old Nov 15, 2012 | 11:46 AM
  #38
It's Me Patt's Avatar
It's Me Patt
The swivel is ok in the link..If the bushing (not sure if that's the name for it) is shot get a new pitman and get a greaseable type..Pretty easy /removal install. Need to mark the arm and shaft (*important*)for proper install..supposed to use a special tool to remove the arm..check the shaft to make sure it's not stripped (good teeth and tight fit)..install new arm..get an alignment..Approx $20-50 from rock auto and use this discount
code 118254649364174 There might be a write up in the DIY section here better than mine. I think the torque on the nut is 185 ft/lbs
Old Nov 15, 2012 | 02:23 PM
  #39
cutthroatxxx
So how am I sure the pitman arm is bad?&Wont it be better to use polyuratheine bushing?
Old Nov 15, 2012 | 05:47 PM
  #40
It's Me Patt
If the boot is jacked, if the teeth are stripped..and yes I would use one with a poly bushing..your drag link end might be shot as well..as stated in the last post the price range will kinda dictate weather you get a non greaseable or greaseable or with a poly bushing
