Will 46re from Jeep work for my Ram?
Old Nov 21, 2012 | 04:11 PM
FfBill's Avatar
FfBill
Default Will 46re from Jeep work for my Ram?
My trans is out in my 97 Ram 4x4.
I found another 46re but it's from a 98 grand Cherokee 5.9.
Will it be the same as a ram 46re or different? I already got one wrong trans, owner gave me a 46rh and it won't work. Hoping to get something thatll work!
I've tried looking it up and got conflicting answers, just trying to find somebody that knows for sure, thanks !
Old Nov 21, 2012 | 08:52 PM
jconlin's Avatar
jconlin
as long as the years are compatible. i think it is the same for all vehicles, that year but i do know they change with different years
Old Nov 22, 2012 | 06:49 AM
It's Me Patt's Avatar
It's Me Patt
a 46re is a 46re..no diff there..what was/is in the truck now?
Old Nov 22, 2012 | 09:15 AM
FfBill's Avatar
FfBill
Trans wise a 46re. I put in the one that was given and the plugs are different and the overdrive unit is too long making the driveshaft not fit
Old Nov 22, 2012 | 10:17 AM
h3lzsn1p3r's Avatar
h3lzsn1p3r
will no fit with out changing conector pigtails so i am reading
Old Nov 22, 2012 | 12:10 PM
It's Me Patt
I actually meant org what was in it? Must not have been a 46re in it before then
Old Nov 22, 2012 | 12:20 PM
It's Me Patt
some reading for ya..Don't believe everything you read tho
http://en.wikipedia.org/wiki/Dodge_Ram
Old Nov 22, 2012 | 12:40 PM
FfBill's Avatar
FfBill
I installed a rh and it didn't work
H3 can u send me a link to where u read that?
Old Nov 22, 2012 | 01:49 PM
gdstock's Avatar
gdstock
RE and RH are not interchangeable. Controlled differently.
For best result and to assure proper fit, need to match years, 2wd or 4wd, etc. and engine size if possible (for flex plate issue).
Old Nov 22, 2012 | 10:15 PM
It's Me Patt
I don't get it you tryed installing both and neither worked ??
gdstock made it real clear for you hope THAT helps!
