Plugs
Old Dec 8, 2012 | 01:03 AM
rthompson's Avatar
rthompson
explain exactly what you mean by tune? You mean a chip or performance PCM?
Old Dec 8, 2012 | 03:21 AM
kejobe's Avatar
kejobe
The ECU will have to be reprogrammed to run properly with those mods. A "tune" is just a loose term used for the reprogram.
Old Dec 8, 2012 | 07:49 AM
Halojm's Avatar
Halojm
Originally Posted by rthompson
Well I got a buddy of mine that owns a shop and does good work. When I mentioned the timing belt he told me to go all gears and no belt and while I am at it swap the cams as well. He offered the put in performance cans, new timing gears, M1 performance intake manifold, 1.7 HS roller rockers and a performance distributor cap for $500 only (I provide the parts). Pair that along with a CAI and 52mm Throttle body already in it I would assume all that would be almost a 100hp jump and close to the same with torque am I right?
Well if your going all out like that, you should include a throttle body spacer, in conjunction with the air foil, and one of those magnet fuel rail optimizer things.
Old Dec 8, 2012 | 09:21 AM
Yep. or, the other alternative would be just changing over to a standalone system, that you can program yourself with a laptop. Expensive, but, might end up being cheaper in the end.... especially if you end up having to send out your old 94 pcm to be reprogrammed multiple times to get it right, at 250 a pop.......
Old Dec 8, 2012 | 11:52 AM
Hahns5.2's Avatar
Hahns5.2
Performance cans? You mean cam?
I had 1.7s and an M1, with 7PSI of boost on top of that to get a 120hp increase.
Without worked over heads, a decent cam, and a method of tuning, keep dreaming.
Old Dec 8, 2012 | 09:21 PM
rthompson's Avatar
rthompson
Well he did say 100hp optimistically. Realistically with a tune I was guessing max of 75hp or less.
Old Dec 8, 2012 | 11:55 PM
SilverSS's Avatar
SilverSS
Honestly I don't think it will be close to 75- maybe 1/2 that. Should sound great with a healthy cam in it though
Old Dec 12, 2012 | 01:12 PM
rthompson's Avatar
rthompson
What is in these engines that cause the yield to be so low? Most of the parts like cams rockers and the M1 each quote a 20hp gain minimum so when all added I will only see 30? How is that?
Old Dec 12, 2012 | 01:22 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Because Magnums are inefficient.
Unless you boost them, like Hahns...
