Transfer case BUSTED?
Old 12-08-2012, 08:32 PM
dlyter09's Avatar
dlyter09
dlyter09 is offline
The first one was bearings.. The other ones had cracked.. The cracks were pretty much identical with the last 3....
Most Recent.
[IMG][/IMG]
Thats the second case..
[IMG][/IMG]
I cant seem to find the other pictures at the moment but thats how they started... I saw the cracks before it got bad and was swapping them out.. Then the most recent I never saw a crack until it let loose and ripped apart..
  #42
Old 12-08-2012, 08:34 PM
dlyter09's Avatar
dlyter09
dlyter09 is offline
Originally Posted by Spillage
dlyter09,
Looking at the bottom right of the first pic, and to top of the second pic, it seems like the housing was already cracked for some time before it let go.
See how the broken casting in those areas are dark/dirty, whereas the fresh break is clean and shiny.
Its dirty for a reason.. It dropped out of the truck when I pulled the linkage..Went straight into the ground... It was all fresh breaks cause I had just been under the truck a few days prior to check on everything and there was no cracks or anything loose..
  #43
Old 12-10-2012, 12:27 PM
Timothy Watrous's Avatar
Timothy Watrous
Timothy Watrous is offline
? do all of you shift into 4hi wiel driving? just a thought... i know it says you can in the manual. but its posible that could be the problem
  #44
Old 12-10-2012, 12:43 PM
dlyter09's Avatar
dlyter09
dlyter09 is offline
Ive done it with every dodge and jeep I have owned.. This is the first one I ever had a problem with.. All of my cases went out after the front driveshaft was removed..
  #45
Old 12-10-2012, 01:02 PM
aofarrell2's Avatar
aofarrell2
aofarrell2 is offline
Same here... 4HI on the fly, 4LO on the slow... That's my saying to remember
  #46
Old 12-10-2012, 01:54 PM
dlyter09's Avatar
dlyter09
dlyter09 is offline
Yea exactly.. this is the first I have had any issues so that is not the cause of the breaking
  #47
Old 12-10-2012, 02:28 PM
merc225hp's Avatar
merc225hp
merc225hp is offline
Put one of these in it lol NEW VENTURE Model: MP-1528 I might be ezer to do than one thinks. For me when going into 4wd L I come to a complete stop then shift.
http://www.heavytruckparts.net/detai...1&searchnum=-1
  #48
Old 12-10-2012, 07:18 PM
Timothy Watrous
could that be what causes the t case to weaken, but not break till a later date... cus ive always stoped compleatly to switch to 4x4 hi or lo... and havent had this problem yet...(nock on... compressed wood chips, or whatever this desk is made of...)
y not just upgrade to a quick change... http://www.scsgearbox.com/4x4-transfer-cases.html
  #49
Old 12-10-2012, 07:27 PM
dlyter09's Avatar
dlyter09
dlyter09 is offline
Ok explain how my t-cases failed then.... With NO front driveshaft in and not ever touching the 4wd lever once... Its a shift on the fly... You will not have any issues.. Simple... Whenever I would go for 4hi I take my foot off the gas and pull it back into 4hi and continue on my way... 4lo I always came to a stop and put it into neutral then 4lo...
No issues once with my 01 offroad edition.. My 02 Jeep and an 04 Hemi....
  #50
Old 12-10-2012, 07:42 PM
Timothy Watrous
dude it was just a question... idk if u got a used one or not, thats y im asking...
what did u do right befor it blew up? break really hard, jump the truck, roll backwards in drive and punch the gas...? what?
Quick Reply: Transfer case BUSTED?
