Heater Core
Old Dec 9, 2012 | 01:06 AM
vaninator's Avatar
vaninator
Default Heater Core
Ok, so I know my heater core is leaking. Left the inlet hose off and bypassed it to the outlet hose for the past week. Today, I put in a package of those "cadillac pills" and reconnected all the hoses. So far, no leaks, no wet floorboard, and no more steam coming out of the vents. Did i F!*% up by putting those pills in? or should i be alright. I know its not a permanent fix, but i dont have the $ or the time to replace it right now. Or, is it something else like the a/c condenser? Keep in mind there was steam coming from the middle vents AFTER i would turn my truck off and could smell coolant. Please let me know asap so I can quit stressing. Thanks-
Vance
Old Dec 9, 2012 | 02:06 AM
UnregisteredUser's Avatar
UnregisteredUser
You probably just gummed the works. Best bet is to get a heater core and some hoses for it, flush the ever-lovin' out of the thing with the core bypassed (because it doesn't really matter any more), and do the job right.
The big problem is with clogging up the lower passages in the water jacket of the block. There's not a lot of flow down there, but plugging things up down there can cause mysterious overheating problems.
Old Dec 9, 2012 | 09:23 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Bottom line, your truck will explode.
Congrats.
Old Dec 9, 2012 | 11:07 AM
vaninator's Avatar
vaninator
Congrats.
When will it explode?
And what causes it to explode?
Old Dec 9, 2012 | 11:10 AM
zman17's Avatar
zman17
Retired Moderator - RIP
It's not going to explode! LOL
Old Dec 9, 2012 | 11:55 AM
dlyter09's Avatar
dlyter09
lmao haha...
Old Dec 9, 2012 | 12:51 PM
THePaRaSiTE5771's Avatar
THePaRaSiTE5771
Congrats.
Unlike VWandDodge, I will try my best to post a helpful response. Everything that UnregisteredUser said is correct. The worst thing to do to fix a leak on a vehicle is throw those stop leak products in. Either replace the part to fix the leak or don't do it at all. I understand you wanted a quick fix to a leaking heater core, but putting those stop leak products in can lead to more cooling system problems in the future.
Old Dec 9, 2012 | 02:03 PM
dhvaughan's Avatar
dhvaughan
i'll disagree with most everyone and say that the stop leak products don't hurt anything. they stay in solution when in the cooling system and create a hardened crust wherever they leak out and are exposed to air. contrary to old wives tales, it doesn't stop up the radiator or heater core or t-stat.
its a band-aid that may or may not work. if it works - fine. if it doesn't work, do flush it back out when replacing the leaking component.
stop-leak products of long ago that i've used include black pepper and/or an egg. yes, an egg.
Old Dec 9, 2012 | 02:59 PM
vaninator's Avatar
vaninator
i guess I'll keep it hooked up for the next 2 days until it gets replaced
Posted from Dodgeforum.com App for Android
Old Dec 16, 2012 | 12:35 AM
vaninator's Avatar
vaninator
is it possible its my thermostat? soneone told me it could be and that its pushibg coolant through any pin hole it can find
