Will These Rub?
Old Dec 11, 2012 | 09:30 AM
h3lzsn1p3r's Avatar
h3lzsn1p3r
it will be tight but it should not rub
Old Dec 11, 2012 | 09:59 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Originally Posted by ChillyPhil
Danny Gaston only had a factory 2" lift on his ram and put 35s on though. I figured if I put my leveling kit on and my bigger blocks, I might be able to?
http://www.djgaston.com/offroad/offroad2.htm
And once again he was running wheels with a different offset.
Old Dec 11, 2012 | 10:01 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Anybody notice in ChillyPhil's sig that he has spacers on??? With them he may clear w/o rubbing, however, knowing the BACKSPACING is still prudent.
I don't spacers are a good idea other than street use in my general opinion.
Old Dec 11, 2012 | 10:18 AM
FireDodge's Avatar
FireDodge
Plus his is the Off-Road edition Ram, so it sits approx. 2 inches higher than normal ones. So he has like a 4 inch lift if it weren't an Off-Road.
Old Dec 11, 2012 | 11:49 AM
CSDavies26's Avatar
CSDavies26
No its not, look at the tailgate. Although you are correct about the off roads sitting about 2 inches higher. If he had the offroad edition plus the 2" leveling kit, then he could clear the 35s no problem, assuming the backspacing on the rims is sufficient
Old Dec 11, 2012 | 11:55 AM
oxymoron29's Avatar
oxymoron29
FWIW I run 35's on an 8 inch rim with 3.75" BS with 5" lift and I've got loads of space at full lock even with fenderwell covers. Don't take my word for it but I think with 3" and a bit of trimming you could cut it. Go measure the BS.
Old Dec 11, 2012 | 11:59 AM
dodge dude94
Chilly has a 96, no such thing existed back then.
Old Dec 11, 2012 | 12:31 PM
ChillyPhil's Avatar
ChillyPhil
Yeah i have wheel spacers on right now but i didn't want to use them if i got the 35s because it would put my tire way too far out of my fenders and I know spacers aren't good for taking offroad.
I wish there was a way to figure out the offset of the wheels i posted because i asked the guy and he said there wasn't any offset numbers on the wheel. He said i should be fine but I'm still unsure. I know i would probably have to take my running boards off because it'll rub them for sure.
But Danny's only has that 2" lift all around on and I have the 2.5" in front and i want them 4" blocks for the rear. I just don't know what his offset is.
Old Dec 11, 2012 | 12:43 PM
dlyter09's Avatar
dlyter09
Well I think it was Merc who posted how to measure for the offset...Do that or ask the seller to do it.
Old Dec 11, 2012 | 04:46 PM
Measure from the mounting surface, to the outer edge of the rim. Not hard to do.
With only 2" of lift, with mild street driving, you might be ok. Take it off-road though, and you WILL rub. You need more lift, or some body mods to clear 35's.
Danny has an Off-Road edition truck. He starts out 2" higher than you already, plus the additional 2" he put on there is 4" total lift. Which is still kinda tight when you flex it out.
