Spicer u joint part#, FAQ pdf not found
Old Dec 11, 2012 | 11:32 AM
baileysoffroad's Avatar
baileysoffroad
Default Spicer u joint part#, FAQ pdf not found
The Dana spicer pdf (google doc's link) in the FAQ's is giving me a "file not found" Want to order up some new u joints for my 99 ram 1500 sport 4x4...assuming spicer is the way to go without dropping a fortune on something like ctm's
..anyway im going bonkers trying to confirm a proper part number...
..shamefully i found this from another forum while doing a google search..
"Dodge does not use the Spicer 5-760x or 297 in the DRIVESHAFT. Dodge uses Detroit style 7260 or 7290 ujoints (not Spicer style 1310, 1330, 1350, ect...) in it the driveshafts. The Spicer p/n for the 7260 is either 5-1306-1x or 5-1306x, and the (larger) 7290 is Spicer p/n 5-1309x."
Some help here in confirming the proper part number would be greatly appreciated.
Old Dec 11, 2012 | 11:43 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You don't need spicers anyway. Get some Precision u joints at a local parts store. Which shaft are you doing btw?
Old Dec 11, 2012 | 11:45 AM
baileysoffroad
figured i just do em all at once.
Old Dec 11, 2012 | 11:46 AM
baileysoffroad
Let me elaborate, the truck is new to me and ive been going through it, I'll be setting out on a 3000 mile journey with it shortly and i can see the joints have not been replaced in ages so it will make me feel more comfortable having new ones.
Old Dec 11, 2012 | 11:52 AM
zman17's Avatar
zman17
I suggest you take the front DS to a DS shop and let them rebuild the cardan joint. If you really want to do it yourself, get the parts from quad4x4.com you can get a video from them also. The rear is easy and the axle shafts are not too bad. But the cardan joint needs to be right.
Old Dec 11, 2012 | 11:56 AM
baileysoffroad
Noted, ill look into it further...no joint number confirmations though?
Old Dec 11, 2012 | 12:00 PM
zman17's Avatar
zman17
No. Because I use Precision brand. And they are greasable . The spicers might not be.
Old Dec 11, 2012 | 12:44 PM
dlyter09's Avatar
dlyter09
There is an updated thread from a week or so ago where you can download the manuals.. Ill see if I can find it.
Edit: Here ya go.. Check this out
https://dodgeforum.com/forum/2nd-gen...load-test.html
Old Dec 11, 2012 | 12:54 PM
zman17's Avatar
zman17
You mean this one? https://dodgeforum.com/forum/2nd-gen...load-test.html
Never mind, you got it.
Old Dec 11, 2012 | 01:10 PM
dlyter09's Avatar
dlyter09
