Steering Column on Steeringbox Pulling Out
Old Dec 14, 2012 | 12:29 AM
Brian_'s Avatar
Brian_
Default Steering Column on Steeringbox Pulling Out
So i had put a 3in body lift on my truck last weekend and we had skipped the steering extension because firstly we couldn't get the shaft to pull out of the box with the bolt loose and secondly when we got it lifted we saw no binding and assumed it was fine. It appears that it may have pulled out of the steering box somehow, maybe 1/4 inch if that. My question now is how much of the thread is still on there before it completely comes out? and should i try putting my adaptor on it, which is 4 inches longer then what i can even get the shaft to pull out?
any ideas? i dont wonna be driving and loose all steering.
Old Dec 14, 2012 | 09:11 AM
There is a bit left on there, but, I am real curious how it managed to pull out with the bolt still in there. Might be able to put the extension on a little easier now though.... That IS something you want to address NOW. Losing your steering is FAR to exciting.
Old Dec 14, 2012 | 09:53 AM
Brian_'s Avatar
Brian_
has me curious too. i even went monkey tight on that bolt, once we found that the shaft wouldn't even pull out. any tips on a easy way to get that shaft to pull out? pb blaster?
Old Dec 14, 2012 | 10:02 AM
cruzer55's Avatar
cruzer55
You might have to un-fasten the from under the dash to give some needed play,just a thought...........
Old Dec 14, 2012 | 12:56 PM
Chems, take the bolt completely out, and a pry-bar.
Old Dec 15, 2012 | 01:48 AM
Brian_'s Avatar
Brian_
ill give it a go in the morning and see what happens
