Spark plug shield
Old Dec 16, 2012 | 11:17 AM
SquirmyPug's Avatar
SquirmyPug
Default Spark plug shield
Got a 2002 1500 4x4 with the 5.9L. The truck has 29k on it and gets a #8 misfire at startup about once every 3 weeks so I'm replacing the plugs. I'm removing the shields around the plug boot because I can't get the boot out with them in place. I could replace some of the shields but some of them I can't get to. I was reading about these but most of the posts about the shields are old, has anyone had any problems from running without them?
An easy job has become a problem because of the shields, really tight boots, and plugs that make me think I'm going to bust a nut just breaking them free. So far all the old plugs have had about .050 gap, replaced with new plugs gapped at .040.
Thanks for any info about the plug shields.
Old Dec 16, 2012 | 01:33 PM
Halojm's Avatar
Halojm
I've remove all the shields on my 97 Ram, I haven't had a problem without them for years.
Old Dec 16, 2012 | 01:41 PM
Lots of folks have removed them without consequence. A fair few of them actually advocate removing them, as they tend to trap crud, which then likes to fall into the cylinder when you change the plugs. Yank 'em, toss 'em, and don't worry about it.
Old Dec 16, 2012 | 01:43 PM
dlyter09's Avatar
dlyter09
They can be a pain to remove though.. I wanted to remove mine and couldnt get a single one to budge..
Old Dec 16, 2012 | 02:14 PM
SilverSS's Avatar
SilverSS
Same here. I just decided to leave them in. Blow them out with compressed air before I pull the plugs. Have you checked the plenum and catalytic converter?
Old Dec 16, 2012 | 02:23 PM
SquirmyPug's Avatar
SquirmyPug
Got all the shields out without a problem. SilverSS, I checked the plenum about 2 weeks ago and it looked fine and the cat. seems fine. I thought it would be ok without the shields but wanted to make sure. Thanks guys.
Old Dec 16, 2012 | 03:20 PM
dhvaughan's Avatar
dhvaughan
i threw mine away 6 years ago. no problems.
Old Dec 16, 2012 | 04:39 PM
Jimythefan's Avatar
Jimythefan
You can always add boot protectors to the plugs if the manifolds run really hot.
Boot protectors
Old Dec 17, 2012 | 01:15 PM
AtomicDog's Avatar
AtomicDog
The metal spark plug tubes should be removed and thrown in the trash.
I had a set on my original 5.9 motor that allowed all kinds of crud to accumulate around the spark plug. My truck was an original snow plow truck. The plugs were stuck in the heads so bad that I had three plugs that broke off and could not be removed - of course, the plugs that broke were hard to get to at the rear of the motor on the driver's side. I ended up replacing the motor due to rust issues.
Before I installed the 2nd motor, I took the heads off the motor (was going to take the heads to the machine shop for a valve job) and removed all of the spark plug tubes. I just clamped a pair of Vise-Grips onto each tube, rocked it back and forth a bit and each tube came off without much trouble.
When installing new plugs, take the opportunity to spread a bit of dialectric grease inside the spark plug boots to make removing the spark plug boots easy the next time you have to service spark plugs or wires.
Old Dec 17, 2012 | 06:10 PM
SilverSS's Avatar
SilverSS
^^^+1 on dielectric grease. Also I always put anti seize on the threads.
