Massive oil leak
Old Dec 22, 2012 | 05:02 PM
  #31
jpsycoboy5's Avatar
jpsycoboy5
I doubt its the valve cover gaskets, the oil escaping there isn't under enough pressure to spray anywhere.... (unless you have SERIOUS blow-by issues....) There isn't any pressurized oil near the timing cover either...... pressure sending unit is on the back of the block, next to the dist..... not sure if that could cause your issue or not......
Start the truck up, have a friend sit in the drivers seat, put it in gear, and hold the brake.... see if you see any fluid spraying. Or, I suppose, you could put it in neutral, and set the parking brake/block the wheels.....
That's why I'm so lost there's not very many places that much oil can spray from. I already tried getting it to spray in the driveway the only time it works is if you get on the road and stomp on it and rev it out through every gear
Old Dec 22, 2012 | 08:57 PM
  #32
stewie01's Avatar
stewie01
Have u checked the timing chain cover?
Old Dec 22, 2012 | 09:03 PM
  #33
Timothy Watrous's Avatar
Timothy Watrous
only other place i can think of would be posibly a crack in the head were the oil is under presure when it gos up threw the head before it gets to the valves... but still thinking timing chain cover
Old Dec 22, 2012 | 11:20 PM
  #34
No pressurized oil there... valve train is lubricated thru the pushrods. Those don't really flow all that much. I don't think valve covers, or head gaskets are the issue.
Old Dec 23, 2012 | 02:24 PM
  #35
Timothy Watrous
hmmm... my truck has fill caps on both sides you didnt forget to put one back on did u?
Old Dec 23, 2012 | 02:49 PM
  #36
Is your PCV system intact? Or do you have aftermarket valve covers?
Old Dec 23, 2012 | 10:37 PM
  #37
jpsycoboy5's Avatar
jpsycoboy5
No factory everything I wiped down the PCV valve and hoses and it's doesnt get wet again. For the timing cover do I just take off all of the accesories and just look.
Old Dec 23, 2012 | 10:43 PM
  #38
jpsycoboy5's Avatar
jpsycoboy5
Old Dec 23, 2012 | 10:54 PM
  #39
stewie01's Avatar
stewie01
No need to pull anything to check for leaks. What about the crankshaft seal? (front of the timing cover)
Old Dec 24, 2012 | 12:32 AM
  #40
Timothy Watrous
... was this ? directed at me ? ... cus as far as i know there stock...
