Massive oil leak
Old Dec 20, 2012 | 12:53 PM
  #21
jpsycoboy5's Avatar
jpsycoboy5
Are you sure its oil, and not trans fluid??
I'm pretty sure it's oil I've spent my fair share covered in trans fluid haha but I will check
  #22
Timothy Watrous's Avatar
Timothy Watrous
^ im prity sure he check the engine oil...lol
? is the oil spraying on to the fender or is it spraying up at the hood and driping down on the fender?
Old Dec 20, 2012 | 01:20 PM
  #23
jpsycoboy5's Avatar
jpsycoboy5
Yeah haha I'm almost positive it's oil. The fender is covered and the bottom side of the air filter tube but the mat on the hood and the top of the tube isn't wet
Old Dec 20, 2012 | 05:30 PM
  #24
jpsycoboy5's Avatar
jpsycoboy5
I checked the oil filter today it was completely dry and no signs of oil leaking there I've officially run out of ideas I might go buy new valve cover gaskets do you all have any other ideas? Or what I should take pictures of because its hard to get pics where you can actually tell really well
Old Dec 20, 2012 | 05:33 PM
  #25
gertie240's Avatar
gertie240
Oil pressure sending unit? Another guy had a similiar oil leak and the sender was cracked.
Old Dec 20, 2012 | 05:51 PM
  #26
Timothy Watrous
is there oil on the bottom of the alt?
Old Dec 20, 2012 | 06:46 PM
  #27
jpsycoboy5's Avatar
jpsycoboy5
I think so I'll check when I get back to the truck but care to elaborate? Haha
Old Dec 20, 2012 | 06:48 PM
  #28
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
He might be starting to refer to a timing cover leak.
Old Dec 20, 2012 | 07:06 PM
  #29
Timothy Watrous
^ yup ... that would be my gess ...
Old Dec 21, 2012 | 09:10 AM
  #30
I doubt its the valve cover gaskets, the oil escaping there isn't under enough pressure to spray anywhere.... (unless you have SERIOUS blow-by issues....) There isn't any pressurized oil near the timing cover either...... pressure sending unit is on the back of the block, next to the dist..... not sure if that could cause your issue or not......
Start the truck up, have a friend sit in the drivers seat, put it in gear, and hold the brake.... see if you see any fluid spraying. Or, I suppose, you could put it in neutral, and set the parking brake/block the wheels.....
