1996 dodge ram 5.9 magnum Iac or map issues?
Old Dec 19, 2012 | 09:48 PM
Indy500Clone's Avatar
Indy500Clone
Default 1996 dodge ram 5.9 magnum Iac or map issues?
Well hello all, im new to this form as i just recently purchased a dodge ram 5.9 magnum indy 500 clone. . ok so i was reading about the plenum problem , found out my truck had this issue and i ended up buying a m1 intake and installing it with new bolts gaskets, a oem dodge pvc valve and grommet, i also did a full tune up along with the intake swap, champion plugs , 8mm summit racing wires, cap,rotor, oil change, anyways long story short, i reset the trucks battery and everything seemed to be ok but lately its been starting really quick and idle is at a very low rpm below 600 , it fluctuates runs different everytime i drive it, one time low idle and other higher around 1100,i was curious if it could be my map or iac, i cleaned my throttle body before placing it on my m1 intake so im un sure if i ruined sensors on the throttle body or not, i did a check engine light test and got 5 flashs pause 5 flashes, so im guessing theres no CEL. any suggestions on what this could be? also when it idles really low my volts go to the middle gauge and sometimes even lower.
Old Dec 19, 2012 | 09:51 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
If you cleaned the IAC too roughly that could do it. When cleaning the IAC you're not to push or pull the dowel or turn it in anyway. It breaks it. lol
Old Dec 19, 2012 | 09:52 PM
Indy500Clone
Thanks for your reply!
Well I left all the parts intact to the throttle body, just light spray and wipe. could that be my headache at this point?
Old Dec 19, 2012 | 09:56 PM
dodge dude94
Yeah, when cleaning the TB it is recommended to pull the IAC, clean it pretty good and clean the cavity it fits in.
Old Dec 19, 2012 | 10:07 PM
Indy500Clone
ok, ill probably buy a new iac then it was pretty filthy with carbon build up, is there any chance i ruined tps or the map too while cleaning it?
Old Dec 19, 2012 | 10:10 PM
dodge dude94
You should be able to clean it. Just take it out, hit it really hard with TB cleaner (I use CRC Throttlebody and Air Intake Cleaner, works good) and then a steel brush very lightly. Should get most of it off, if not polish the darn thing. As long as you didn't move the dowel any you should be good. Just make sure you do the same thing to the passage in the TB where it mounts.
TPS and MAP's are kinda hard to screw up, they usually go when they want to.
Old Dec 19, 2012 | 10:57 PM
Indy500Clone
ok thanks! truck has 189xxx miles, motor has been swapped i believe, not to subject change but im gonna buy a sct , and i cant find my ecu numbers, theres jus different stickers with warning labels
any thoughts on that, and do you know what the vin would be for a real indy 500 would be? just curious
Old Dec 19, 2012 | 11:03 PM
dodge dude94
IIRC the numbers he asks for on the PCM are the P/N on the PCM.
As far as the VIN for the Indy, just use the VIN on the door or dash plate. IIRC the Indy was pretty much a special paint package. I may be wrong on that. The engine is the same as a regular Ram.
Old Dec 19, 2012 | 11:49 PM
Indy500Clone
ok thanks!
