transmission numbers and identification
Old Jan 2, 2016 | 10:32 PM
  #21
Hhhmmmm..... Could go either way. Definitely for a 2 wheel drive at any rate.....
Old Jan 2, 2016 | 10:54 PM
  #22
Forcer's Avatar
Forcer
What do mean it could go either way? Did the 727 ever come with an hole/slot for the crank position sensor? I believe I'm looking at a transmission from the A518 family 46re/rh not sure if 44re/rh came with the same bolt pattern.
Old Jan 3, 2016 | 10:12 AM
  #23
44, and, I think, even the 42R? will have the same bolt pattern......
Magnum engines started in 92 (318), and 93 (360), I don't really know if they had the CPS on them at that point or not..... I shot of the whole trans might help.
Old Jan 3, 2016 | 04:38 PM
  #24
Travis99Ram's Avatar
Travis99Ram
Old Jan 3, 2016 | 05:27 PM
  #25
Looks a lot like a 46R? trans. Check the connector (white) that sits on top of the valve body just in front of the rear cooling line fitting. 3 pin is RH, 8 pin is RE. RH will NOT work in the 96 and up trucks. It offends the PCM.
Old Jan 5, 2016 | 07:03 AM
  #26
Travis99Ram
It has 3 pins in the white connector.
Old Jan 5, 2016 | 09:36 AM
  #27
That makes it an RH, which will NOT work on your 98.
Old Jan 5, 2016 | 07:52 PM
  #28
Travis99Ram
Thanks for all the help. I knew it wouldn't work in the 98. It's a 4wd. I bought that truck for a parts truck for my 99. Which is also a 4wd. The guy I bought the 98 from, had gotten it thinking it would work, discovered it wouldn't work and then just decided to sell the truck along with the wrong tranny. I don't need it, so I was just trying to figure out what it was so I could sell it.
Old Jan 5, 2016 | 10:17 PM
  #29
Ah, ok, that makes sense. if it works, its worth a couple hundred bucks anyway. Money in my pocket NEVER hurts my feelings.
Old Jan 6, 2016 | 01:57 AM
  #30
Travis99Ram
Yeah that's what I thought. Guy said it was rebuilt. I can't use it so I figured I'd just use it to recoup some of the $400 I paid for the truck. I was just reading on some other site..that the difference between RH & RE. H is for Hydraulic and E is for Electronic. So if that is true wouldn't that make mine a RE transmission?
