OverDrive
Old Dec 27, 2012 | 08:14 AM
byronpen's Avatar
byronpen
Default OverDrive
Ok the last few days I have been having all kinds of problems. First off this truck hasn't seen snow its hole life. Till i moved back from Texas.
While driving in the down poor from last night the overdrive off light came on.
I sure as hell didnt turn it off. So any ideas?
Old Dec 27, 2012 | 08:24 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Trans was too cold maybe. But usually it turns off without setting the light.
Old Dec 27, 2012 | 08:48 AM
Generally happens right before the trans temp light comes on. have you gotten rid of the check valve yet?
Old Dec 27, 2012 | 09:02 AM
byronpen's Avatar
byronpen
no. Whats the reason in doing that. If i remember the check valve is going to my radator?
Old Dec 27, 2012 | 09:06 AM
dodge dude94
When you get rid of the check valve it keeps crap from clogging the line, which causes your trans to run hot as it does not have a cooler any more at that point.
Old Dec 27, 2012 | 09:22 AM
byronpen's Avatar
byronpen
do the make a kit, and were can i get it.
dodge dude94
It's not a kit, you have to get rid of it yourself.
Or pay a buddy in beer.
Old Dec 27, 2012 | 09:24 AM
I just used a piece of trans hose, and couple hose clamps.... others have pulled the line, drilled out the little ball, cleaned the line out, and reinstalled it. Still others have bought the fittings, and made a new line, without the check valve. Couple threads on it in the faq section.
Old Jan 8, 2013 | 06:32 PM
99SilverBullet's Avatar
99SilverBullet
First time here. I am having problems with my overdrive light coming on. soon after the trans temp light comes on. I am now wondering if it is the check valve you guys are talking about. can you tell me where I can locate the check valve? thanks
btw, i have a 99 ram 1500
Old Jan 8, 2013 | 07:05 PM
UnregisteredUser's Avatar
UnregisteredUser
Consult the FAQ/DIY section's check valve delete DIY for photos. That's your best bet. Well, that and to stop driving the thing until you find out why you've got not cooling flow.
