truck stalling...little help please?
Old 12-29-2012, 09:36 AM
Copedawg's Avatar
Copedawg
Copedawg is offline
Default truck stalling...little help please?
Howdy All! My buddy has a 97 (11-96) Ram 1500 (gasser) 4X4 with 102K on it. It stalls when he slows down (lets off the gas) at lights or going in to turns....I really dont have much more than that....Any body know where we can start to look?
Thanks!
EDIT: The vehicle starts right back up with no problems (starting)
ANOTHER EDIT: It seems like when it goes from acceleration to idle it "over shoots" the idle and idles so low it shuts off.
Old 12-29-2012, 09:47 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,280 Likes on 3,027 Posts
Clean the throttle body. I do believe there is a DIY in the faq section detailing the process. Probably the IAC bore is gunked up, or, the IAC has just failed altogether.
Old 12-29-2012, 09:52 AM
Copedawg's Avatar
Copedawg
Copedawg is offline
HeyYou! Thanks! I will look....what is the IAC anyway?
Old 12-29-2012, 10:22 AM
Copedawg's Avatar
Copedawg
Copedawg is offline
I hate to sound helpless...but I can't find it.....I saw something in the "OLD DYI LINKS" but I am not sure If you or someone could lead me just a little further, that would be great!
Thanks!
Old 12-29-2012, 10:41 AM
HeyYou is offline
IAC= Idle Air Control. It's a stepper motor that mounts to the back of the throttle body. It regulates air bypassing the throttle plates to maintain idle speed. Your friends apparently is working as advertised.
Throttle body cleaning DIY. Cleverly concealed in the "old diy links" thread....
Old 12-29-2012, 10:45 AM
Copedawg's Avatar
Copedawg
Copedawg is offline
HeyYou, you are a good man! I will take a look and proceed. I will let you know how it works!
Thanks!
Old 12-29-2012, 10:48 AM
HeyYou is offline
Thanks!
Don't tell anyone though, you will ruin my rep as a drunken, good for nothing, dodgeforum mod.
Old 12-29-2012, 11:21 AM
h3lzsn1p3r's Avatar
h3lzsn1p3r
h3lzsn1p3r is offline
my truck did the exact same check the batery mine was week i changed it and it fixed it self no more problems
Old 12-29-2012, 01:28 PM
Copedawg's Avatar
Copedawg
Copedawg is offline
Update. I cleaned the IAC. I noticed the air cleaner gasket was broken so my buddy is running up to get one now. As a side note WHATS UP WITH THE AIR CLEANER SYSTEM!? What a PITA! Am I doing something wrong or what? LOL!
Old 12-29-2012, 01:32 PM
QuadCabLuv's Avatar
QuadCabLuv
QuadCabLuv is offline
No its almost a 2 man operation until you figure it out. Its easiest to remove the whole cleaner than it is to pull it apart. Dido on iac and battery.
Quick Reply: truck stalling...little help please?
