Idle Issues
Old Jan 1, 2013 | 09:37 PM
dixiesouth09's Avatar
dixiesouth09
Default Idle Issues
I have a 98 1500 4x4 5.9 and i have recently put a different engine in it and it has idol problems. Its an intermittent problem. The truck will run fine until i come to a stop sign/light or let it warm up on cold mornings. It sounds like to me like it loads up like its carburated, until it almosts dies but when i mash the pedal to the floor for a second or so and let back off it will run fine. And every so often it will do it drivin down the road. So I got the idea one day when it happened i put it in neutral and held the throddle at the same as if i was still under power, and givin a couples seconds it smooths back out. Thinkin the transmission might have some to do with it, be it vaccuum lines or whatever. I was thinkin it might be the TPS but im not possitive. Anyone have any ideas?
Old Jan 1, 2013 | 09:40 PM
The PCM knows when the trans is not in gear, and leans the mixture out accordingly. If you are indeed running rich, what you are experiencing would be completely expected.
I don't think it would be a TPS problem... but, it sure wouldn't hurt to test it.... (got a multimeter?) Is your temp gauge reading 'normally'?
Old Jan 1, 2013 | 10:16 PM
UnregisteredUser's Avatar
UnregisteredUser
So... when you first start it, it idles okay for about a minute then starts sucking wind? Is that the scoop?
Old Jan 2, 2013 | 07:09 AM
dixiesouth09
Theres timea its a little longer but this has happened with the previous engine that was in it. It sounds like a drag car with a huge cam in it, to a point, then the idle lowers until it will almost die.
Posted from Dodgeforum.com App for Android
Old Jan 2, 2013 | 07:32 AM
Unplug the front O2 sensor, and see if that doesn't improve its attitude any. If it does, replace it.
Old Jan 2, 2013 | 08:07 AM
h3lzsn1p3r's Avatar
h3lzsn1p3r
test your battery before you start replacing parts
Old Jan 2, 2013 | 08:18 AM
UnregisteredUser
That's why I asked. Sounds like an oxygen sensor problem.
Old Jan 2, 2013 | 04:25 PM
dixiesouth09
Ill have to give thata a try
Old Jan 2, 2013 | 08:17 PM
QuadCabLuv's Avatar
QuadCabLuv
Check battery and iac.
