What next I have $$$$
Old Jan 3, 2013 | 10:55 PM
Lemunman's Avatar
Lemunman
Default What next I have $$$$
I have a dodge ram 1996 1500 5.2 with 4x4 SCT tuner shorty header cat delete true dual e-fan 1.7 roller rockers k&n 14x3 ,3.55 gears...5 inch lift 3 inch body new 35x12.5x20...... I recently came upon some money say I had about $2500-$3000 where can I go from here I want a diesel but would hate to get rid of this truck I've done so much to it. What would you guys do?
Old Jan 3, 2013 | 10:57 PM
dlyter09's Avatar
dlyter09
Build your axles... Atleast do some gears and locker.. Throw in the posi-loc to
Old Jan 3, 2013 | 11:08 PM
CSDavies26's Avatar
CSDavies26
either what he said or throw a stroker in that bad boy....but you really should be doing the axles and gears first...ive heard good things about the yukon performance gears
Old Jan 3, 2013 | 11:10 PM
dlyter09's Avatar
dlyter09
A stroker is for sure out of his price range.. I run Yukon gears and have nothing bad to say about them... Depending on how he drives his truck he could either do 4.56's or 4.88's
Old Jan 3, 2013 | 11:12 PM
CSDavies26's Avatar
CSDavies26
Yup just realized that hahah for some reason i had 2500 in my head for the stroker. just a wee bit off...
Old Jan 3, 2013 | 11:15 PM
dlyter09's Avatar
dlyter09
lmao yea just a tad bit
Old Jan 4, 2013 | 07:10 AM
dhvaughan's Avatar
dhvaughan
lol. stroker = $$$$$
everything else = $$$ or $$$$
if you want lift and big tires, then +1 that gears are your best (and most expensive) mod. do the calculations to decide what rpm you want to run at 55 and 70 or whatever.
Old Jan 4, 2013 | 07:42 AM
stewie01's Avatar
stewie01
I don't see it anywhere obvious but have you checked/fixed the plenum yet?
If you're still running the stock intake switch over to either Mopar M1 or the Hughes FI AirGap.
Old Jan 4, 2013 | 08:24 AM
Adobedude's Avatar
Adobedude
Transmission
Old Jan 4, 2013 | 08:36 AM
Lemunman's Avatar
Lemunman
Wow thanks guys great advice .. I do have the huges plenum aluminum piece sorry for got that with kegger mod. Ima low end kind of guy . Can I put 4.56 in my 1500 axles with 35 Toyos? Where I live you got to drive atleāst 20 miles on way to hit anything over 55mph.. I do light towing once a month and offroad when the mood strikes only muddin no rocks. Also is USA standard gears and install kit okay I heard they are Yukon actually..
