no balls
Old Jan 13, 2013 | 06:14 PM
  #21
duckslayer5032's Avatar
duckslayer5032
mud was pretty deep but not the worse I been through but my check engine light just came on on my way to work so I'm guessing that's gonna tell me the problem now, but can't check it til tomorrow working 12s
Posted from Dodgeforum.com App for Android
Old Jan 13, 2013 | 06:36 PM
  #22
duckslayer5032
cylinder 1&3 misfire along with random misfire, found a AutoZone close to work
Old Jan 13, 2013 | 06:39 PM
  #23
dlyter09's Avatar
dlyter09
Check all your wires... Have they been routed per the TSB?
Old Jan 13, 2013 | 06:43 PM
  #24
duckslayer5032
yes routed by tsb all plugs and wires are seated properly
Old Jan 13, 2013 | 07:01 PM
  #25
Spray some water under there with the engine running. (just need a mist, don't need to use the garden hose) Best when done when it's dark out, get to see the light show that way.
Old Jan 13, 2013 | 07:03 PM
  #26
duckslayer5032
to see if its sparking?
Old Jan 13, 2013 | 07:04 PM
  #27
If you get a light show, it indicates that your plug wires are 'leaking'... the spark energy will take the path of least resistance. If that ain't thru the plug.... you get a miss.
Old Jan 13, 2013 | 07:21 PM
  #28
duckslayer5032
I wont be able to do so at night til Tuesday night thanks for the tip
Old Jan 13, 2013 | 07:55 PM
  #29
duckslayer5032
could the crank sensor possibly getting wet? anyone know where their located on these trucks?
Old Jan 13, 2013 | 08:04 PM
  #30
baileysoffroad's Avatar
baileysoffroad
https://dodgeforum.com/forum/2nd-gen...on-sensor.html
