E- Brake help! Damn Salty Michigan Roads...
Old Jan 14, 2013 | 11:04 PM
goblueram's Avatar
goblueram
Default E- Brake help! Damn Salty Michigan Roads...
I had My wife drive my truck home the other night and she parked our 1998 Dodge ram 1500 on our steep icy driveway... Not thinking she pushed the E-brake in and let it sit. A couple days later I went out to drive the truck and low and behold I tried to release the e-brake with the lever and nothing would release... So I got a hold of one of my friends who is a GM mechanic (I don't know a mopar mechanic) and he suggested that I just cut the e-brake line and it should disengage. I then cut it and it's still engaged... Any suggestions would be great at this time. Thanks
Old Jan 14, 2013 | 11:07 PM
crazzywolfie's Avatar
crazzywolfie
learn to drive in reverse till you wear enough pad down to get the drums off.
Old Jan 14, 2013 | 11:15 PM
goblueram's Avatar
goblueram
Default I wish...
I wish I could even get this piece in reverse...
Old Jan 14, 2013 | 11:29 PM
crazzywolfie
why can't you get it in reverse? park brakes don't work in reverse. you could try just starting the truck and stand on the brake pedal a couple of times. it might loosed the breaks up a tiny bit.
Old Jan 14, 2013 | 11:42 PM
goblueram's Avatar
goblueram
Default your last post got me to thinking...
I forgot we had really rough snowy weather the night she drove it... The biggest problem looks as though she had the truck engaged in 4 wheel... then at some point it dis-engaged into neutral so it threw everything out of wack... I appreciate your sarcasm at this point it got me thinking... cheers
Old Jan 14, 2013 | 11:44 PM
goblueram's Avatar
goblueram
Default mods feel free to delete thread
Issue resolved Thanks!
Old Jan 14, 2013 | 11:45 PM
crazzywolfie
where did you cut the cable? if you cut them right behind the drum you might be able to get them to release.
Old Jan 14, 2013 | 11:53 PM
goblueram's Avatar
goblueram
Default I cut them both behind...
The drums popped the truck back into 2 wheel and were rolling again... Like i said before you got me thinking earlier... So i went out and drove it down the street no problem... should I be alarmed about anything going forward?
Old Jan 14, 2013 | 11:57 PM
crazzywolfie
if the park break pads are still engaged the truck may not want to go forward. if it feels normal driving forward then they most likely popped free.
