Torque converter not locking?
Old Jan 15, 2013 | 06:11 PM
Clutch plates were brought up, but, they are not part of the valve body. Getting to them to change them would require complete disassembly of the trans. (I.E. a rebuild....)
Old Jan 15, 2013 | 11:57 PM
97tn4x4's Avatar
97tn4x4
If were clutches how would it shift good thhrough all the gears just not lock up?
Old Jan 16, 2013 | 01:05 AM
gdstock's Avatar
gdstock
Lock up - or no loclk up is controled by a solenoid on the VB. Coule be bad connection, debris blocking it, TC failure, or problem in VB with low pressure. I would put a set of gauges on it and see what is going on.
Old Jan 16, 2013 | 01:40 AM
97tn4x4's Avatar
97tn4x4
Any chance on elaborating on the gauges lol? When it was rebuilt the guy firmed the shifts up shall we say and it'll snap pretty good. It still shifts the same though just no lockup. I'm gonna clean the main connector and drop the pan cause I need to change fluid anyway. I just hope it's not gonna be pricey.
Old Jan 16, 2013 | 07:22 PM
97tn4x4's Avatar
97tn4x4
After talking to few peeps, does anybody think that TC itself has took a dump on me?
Old Jan 16, 2013 | 09:03 PM
dhvaughan's Avatar
dhvaughan
i would still take it back to the rebuilder and ask them to check it out. if they know what they're doing, they should be able to determine what's wrong in just a few minutes and likely won't cost anything for diagnosis unless they have to dig into it.
Old Jan 16, 2013 | 09:19 PM
97tn4x4's Avatar
97tn4x4
I may do that but I'm worried cause I don't know what it is and it's a hour and a half drive. I read it could be a tps cause I do have a slight rpm flutter.
Old Jan 17, 2013 | 08:48 AM
Wire the switch for the TCC, just as a test. That will tell you if it is an internal problem, or something electrical.
Old Jan 17, 2013 | 10:27 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by 97tn4x4
Ok so the other night I was driving home and the truck just didn't feel right, and I noticed my rpms higher than normal. I stopped and cut the od switch off and took off and counted the shifts and didn't notice the tcc lockup. I stopped again cut it back on then off again, took off again and then it locked up, cut the switch on again and all was good. Now this morning on the way to drop the kid off at school all was good, on my way back it again wouldn't lock up. Nothing I could do would make it lock. I pulled out the trusty sct and I'm getting a p0734 which appears to be a 4th gear ratio incorrect or something. The trans is rebuilt with maybe 10k on it and I doubt it's that high honestly. I'm fixing to go the the dr and Im gonna clear the code and see what it does now. I'll report back and any help would be great.
This is somewhat similar to what I had happen last fall. At idle I would have engine rpm flare. Shifted fine all gears, until getting up to 4th. Then there would be engine rpm flare.
One test I did was tapping the break pedal to see the response on TCC lockup. I'm having trouble recalling exactly, but I'm sure I did it with O/D on and off. I was trying to isolate whether it was TCC lockup issue. This was also recommended to me by a reputable tranny contact.
I ended up replacing the TPS for kicks and that was the Jeopardy answer.
I did not get any codes though...
Hope that helps.
Old Jan 17, 2013 | 04:56 PM
97tn4x4's Avatar
97tn4x4
Anybody got a link to what wire I need tap into for tcc? I assume that said wire I just a ground too correct.
