300-350hp out of a 318 or 360
hey guys had a question ive got about $2600 saved up for my motor rebuild and im looking to get in the 300hp range out of either a 318 or 360 whichever is gonna be more bolt on instead of machine work i am gonna bore whichever block i get no matter what i just need to know what i need to do to get close to that hp my parts will be cheaper as i am a mechanic and can order through my parts dealer and have the tools to do the job i have the 318 now in my truck but can get a 360 from a junkyard i was thinking bored ported and polished with a thumper cam new pistons intake upgraded tb headers not sure what else to do but i need to keep it in the 2600 range dont necesarily have to get 300hp but want it to be more powerful than it is let me know what yall think thanks
Agreed.. It is possible for those numbers out of both motors but it will be more than 2600... A 408 would be your best bet.. There was a fella on here who did a 408 and he was well over 5k and not even done with it yet.. You also have to factor in the cost of a better transmission behind that 300-400 horse motor as these 46re transmissions will crumble under stock 318 and 360 power.
I agree with trans not holding up but definitely not that you can't get 300 hp out of a 360 for 2600. A good refresh on the bottom end, 2.02 Odessa heads, small cam depending on exactly what you want, and the normal bolt ons will get you 300. Last o checked the thumpr wasn't out for the magnum yet, they had a retro fit cam that would work but it required machining for the proper valve springs. If it's just that sound you want the Hughes whiplash cam would fit the bill though.
I totally agree on that, but adding 55 more ponies at the crank wouldn't be that hard. Depending on what he wants 30 over and slight bump in compression would net more. He says he can get parts cheaper is one reason I say it's easily doable. I had a parts list I had compiled to get 400 ish at the crank on mine but I'd have to find it. I all fairness 1 hp per ci is childs play these days. It's really not hard you just have to research and shop around to get the right parts at the best prices.
Trending Topics
You can get close to that with just bolt ons, and a tune.... roller rockers, M1, or hughes air gap, headers and free-flowing exhaust, you would be close to 300 at the crank....
Doing the cam, heads, intake, exhaust could do 350 without too much trouble....
blower on the stock motor would do either in a heartbeat.... but, engine may not last long. Trans sure wouldn't.....
